Using older Pentax lenses
Posted 19/02/2009 - 09:07
You can use them if you activate the custom menu item "permit use of aperture ring" and then use stop down metering in manual or aperture priority.
If you do a search on this forum you will find lots of threads covering the details in great depth.
The lenses are definitely worth using, they will just be a little less convenient than A lenses and later.
20 years
New Zealand
Angenieux 35mm, Rodenstock 135; Auto-Takumar 55mm, 85mm; Takumar 135mm, macro 50mm, FA 85mm
