Using K100D and older flashguns
Posted 03/08/2011 - 00:11 - Helpful Comment
If you set the K100D to P and the flash to one of the two Auto modes then it should work as a fully automated program flash, with the aperture being set according to the ISO you pick.
You can also use those modes with the camera in M, in this case you set shutter speed, ISO and aperture to what the flash expects and the flash's own light sensor will determine the correct output.
I'm not sure what the max sync speed on the K100D is, on my K-m it's 1/180.
Posted 03/08/2011 - 22:01
In P , its sets the shutter speed to 1/30? But it seems to work ok as long as you don't use bounce or swivel. I guess that's down to trial and error - at least that's much easier on digital!
Posted 03/08/2011 - 22:26
On my K-m it sets it to 1/45 or so, which is ok with SR.
To be honest you'd be better off finding the max sync speed and setting the camera to that in manual mode, it'll be faster than 1/30. I know I've used an AF160 before now, just setting the camera to what the flash expects and letting the flash's own sensor deal with the rest worked well enough. I think I was able to find mine on the Dimitrov K mount site's page for the camera.
The flash sensor can't cope with bounce or swivel as it's unable to work out how much light will be reflected from whatever you're using to bounce the flash. In those scenarios you can adjust the aperture to improve matters or switch the flash to manual too and adjust the power output.
North Wales
