Use K10d with Sunpak auto 220 ?
Posted 15/09/2009 - 14:18
I couldn't find that exact model on the photo trigger site, http://www.botzilla.com/photo/strobeVolts.html
So your safest bet would be to measure the trigger voltage at the pins.
Use a digital volt meter.
Posted 15/09/2009 - 15:02
Thanks for your reply.
There is only 1 pin on the base. I have a digital voltmeter. How do I check this voltage ?
Thanks again.
Thanks again.
__________________________
Best Regards
Skronk
Best Regards
Skronk
Posted 15/09/2009 - 18:02
You will find that there is also a metal "earth" if you look.
Posted 15/09/2009 - 20:02
It's usually on the side of the foot.
Hold one probe on each and fire the flash manually - that'll give you your reading.
Joining the Q
Posted 15/09/2009 - 22:01
You don't need to fire the flash. It's a permanently open circuit waiting to be closed.
Posted 15/09/2009 - 22:28
I am still a little confused as too what is a safe voltage I hear everything from 30 to 300volts is ok, but then others say no more than 30volts. :
I just stick to using Pentax/Metz brand flashes and forget the rest.
Camera:|K-7|
Posted 15/09/2009 - 22:49
Do this carefully folks. Some flashes have very high voltage and it's DC so can give a very nasty bight.
Make sure the meter and leads are up to the job and your fingers are nowhere near the metal bits.
Posted 16/09/2009 - 01:24
mea culpa
Joining the Q
Isle of Skye
Just been given this flashgun. Brand new, never been used. Would it be safe to use with my K10d?
I appreciate I would have to use it non automatically.
Would it be safe. Don't want to wreck the camera !
Thanks.
Best Regards
Skronk
