Urgent Power Supply istD
Posted 30/05/2007 - 21:16
In general electronic terms, a device that is supplied with a lower voltage than that for which it was designed may function perfectly well. This assumes that enough current (demanded by the device) can be supplied whilst the lower voltage is sustained. It also depends on how much lower the supply voltage is. With a new set of alkaline batteries installed, the camera is powered from a 6 volt supply (4 x 1.5 volts per cell). With NiMh rechargeables, the voltage is likely to be less than 6 volts.
Supplying a higher voltage is courting disaster. Don't do it.
I do not recommend, in fact I suggest you do not, connect anything other than the Pentax power supply to your camera.
You have to ask yourself only one question before you connect a 'mickey mouse' power supply to your camera, and that is, can I afford to destroy the camera?
I'm betting you paid less than a fiver for your power supply. How much would it cost to replace the camera if/when you destroy it?
Regards,
Regards,
Posted 31/05/2007 - 00:06
Thanks for the answer. I thought so and will not be connecting!!
purpleperson
Posted 31/05/2007 - 11:47
You might like to have a look at the one mentioned
https://www.pentaxuser.com/forum/viewtopic.php?t=1213&highlight=istd+power+supply. It has 6.5v output. I think the istD needs the extra over 6v due to an internal protection diode.
Sevral of us have used this and it seems to work
Andy
Andy
20 years
I have bought one of those multivolt power supplies. The options for the voltage on the power supply are 3v 4.5v 6v 7.5v 9v and 12v and marked as 500mA 6VA(max) but on the camera is marked 6.5v.
Is it safe to use 6v and will this work? Any thoughts?
Thanks.
