Ultrazoom
tonyK5
Posted 12/03/2013 - 15:58 Link
Hi folks,
I am thinking of purchasing a Sigma 150-500mm for wildlife shooting etc.
Is this the best I can get for ~£500.
Any advice much appreciated.
Tony.
Pentax K5, 18-135mm, 80-320mm, 18-250mm, 50mm F1.7, 200mm DA*, 2 x 16-50mm DA*
Blythman
Posted 12/03/2013 - 16:21 Link
By a country mile
Alan
vic cross
Posted 12/03/2013 - 20:02 Link
Unless you want to spend a little more then the Sigma 50-500 gives greater scope. Commonly known as the BIGMA.
CHEERS Vic.
Typo correction. Vic
Edited by vic cross: 12/03/2013 - 20:03
cedricd
Posted 12/03/2013 - 20:56 Link
Nothing wrong with the 150 - 500. May be good to support it if you want to walk about with it. I use a bicycle quick release toe clip strap attached to my camera bag strap to take some of the weight off my neck.
Enjoy life
davidstorm
Posted 12/03/2013 - 21:37 - Helpful Comment Link
CHEERS Vic.
I've owned the 50-500 and currently own the 150-500. From my experiences with these lenses, the 150-500 is much better (a lot sharper throughout the range) and is also cheaper. I'm delighted with the performance of the 150-500; but was extremely disappointed with the 50-500. It could have just been a poor copy, but I can't verify this. Also, the 50-500 is a lot more expensive.
You could well find a mint or near mint 150-500 for less than £500, mine cost £350 from a fellow forum member and it's virtually brand new, not a mark on it anywhere. I would highly recommend it.
PIRATE
Posted 12/03/2013 - 23:18 Link
How about the Sigma AF 120-400mm DG APO OS HSM? See item: 190807448120. £499.00 delivered (new) from SRS and qualifies for the 3 year extended Sigma (UK) warranty when registered online.
tonyK5
Posted 13/03/2013 - 08:12 Link
Thanks for your comments guys.
SRS have one on ebay for £500 but based on Davids knowledge I may wait and see if I can get one cheaper. Pirate- I was also looking at the 120-400mm, but I am losing a lot of range at the long end and I think the 500mm makes better sense.
Another question - Can I shoot it handheld and still get nice sharp images or will I need a tripod to use it most of the time?
Thanks again,
Tony.
stub
Posted 13/03/2013 - 08:59 Link
You can use it hand held. But its not good over long periods. I would recommend a monopod with a basis head, out in the field.
Stuart..
fritzthedog
Posted 13/03/2013 - 09:26 Link
I own the 120-400 and the 150-500. I use the 120-400 when I need to hand hold - e.g. airshows. It is much more comfortable than the 150-500 and I have no issue hand holding it for 2-3 hours which I can not do with the 150-500.
Also worth noting that the 120-400 is slightly faster and in my experience slightly sharper (but not much in it).
As for the loss of range - actually it is not as great as you may think. I sometimes go out with both lenses on different bodies and the 'real' difference when you use both together dos not seem as big as the 20% difference suggests.
I would also point out that in the real world - you will be shooting between min and max - not just at max. So the question becomes - how often do you need 500mm vs 400mm?
Not so easy to answer - I bought the 150-500 believing it would give me significant advantages over the 120-400 but discovered that there are not many times it does. I intended selling the 120-400 - but can not seem to let go of it because it has the advantages listed above.
If pushed and had to lose one - I would keep the 120-400
Carl
Edited by fritzthedog: 13/03/2013 - 09:28
tonyK5
Posted 13/03/2013 - 11:54 Link
Thanks again guys.
From reading up on the 400mm vs 500mm most people cannot split them, so I will work on the assumption that bigger is better and go for the 150-500mm.
Plus I have a bit of an obsession with the moon, so that extra 100mm may help me pick out the little green men a little better!
Thanks again.
Tony.
Posted 13/03/2013 - 12:39 Link
The 150-500mm feels more like 450mm at the long end(500mm)
so the extra 100 is more like 50..
Tony.
Blythman
Posted 13/03/2013 - 12:46 Link
I almost always use the 150-500 handheld. Most used lens.
Alan
davidstorm
Posted 13/03/2013 - 20:45 Link
I have no problems shooting the 150-500 hand-held. It is heavy, but if anything that weight is an advantage and helps me to keep it steady.
Mike-P
Posted 13/03/2013 - 21:40 Link
I believe Davids is the non OS version so you can't really compare them price wise. Doesn't make much difference on Pentax a we have it in body (apart from you get a stable image in the viewfinder with the OS lens) .. not sure if they are optically identical though ?
davidstorm
Posted 13/03/2013 - 22:30 Link
I'm really not sure whether the 50-500 non OS is optically the same as the 50-500 OS version. However, I have the 150-500 non OS and I understand this is the same optical formula as the OS version of this lens.
I really don't feel the need for OS, even in a long lens, as I've never seen any indications that the in body stabilisation is anything but extremely capable. Very few of the shots I've taken with the non OS 50-500 or 150-500 show any indications of shake.
