Tripod ball heads
Posted 27/05/2012 - 17:33
Do you have the camera attached to the QR plate in the right direction? I cant see how changing from landscape to portrait needs a leg to be adjusted.
Posted 27/05/2012 - 18:41
I have a giottos tripod with a pan and tilt head. Going from landscape to portrait was simple, found it a puzzle when I wanted to be in portrait but with the lens tilted up or down, equivalent to pan left or right in landscape, don't ask why I'd want this I've bought a ball head which simplifies things in that respect. So what I want now is one of those tripods with a movable center column, just to polish off what is left of my sanity
Posted 27/05/2012 - 19:05
A ball head may make it easier, tough it could depend on the ball head - some have two notches to tilt the camera into, some only one.
I've only had a ball head so am not familiar with pan & tilt heads.
An L plate would make it easier still.
Posted 27/05/2012 - 19:11
When I put the tripod head into portrait mode the camera lens is parallel to the ground. I am then unable to tilt it up or down.
Pentax K5, Kx, DA15 ltd,18-135, 18-55, 50-200, M100 f4 macro, M135 f3.5 A28 F2.5
Posted 27/05/2012 - 19:12
Don't think there is a L plate for the K5
Posted 27/05/2012 - 19:35
RRS make one, Kirk make a universal one and there are a few on flea bay I believe.
Posted 27/05/2012 - 19:56
johnboy-22 wrote:
Would a ball head solve this problem.
I doubt it .... a thinking head might!
Posted 28/05/2012 - 07:05
Is there something still locked?
Posted 28/05/2012 - 07:20
No, one handle rotates the head into portrait mode. The other one then works the same as the bottom lever to rotate the head for a panorama etc,
Posted 28/05/2012 - 12:43
I don't have Giotto kit (all Manfrotto) but don't have a problem with my 3way head. I don't suppose that there is much difference.
Do you have a model number or photo of your head to show the problem
regards
Bernard
regards
Bernard
Posted 28/05/2012 - 17:47
redbusa99 wrote:
i have a giottos MTL 9361B tripod with MH5001 pan/tilt head and there is no problem moving up and down in portrait position with this. it may be your head is not 3 way pan/tilt
Problem solved. I had put the quick release plate onto my camera 90deg out. It now works the way it should. Put yours on like mine just to see what I happens.
Posted 28/05/2012 - 18:04
If only I had understood what you were meaning Ken. It is now blindingly obvious.
Turnberry,
Ayrshire
