Tripod ball heads?
Posted 03/10/2021 - 15:54
https://www.amazon.co.uk/gp/product/B08XZHX1P7/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
I bought this for precisely what you want it for and it's perfect.
Hope that helps!
Hope that helps!
Posted 03/10/2021 - 16:33
Hope that helps!
John Rhttps://www.amazon.co.uk/gp/product/B08XZHX1P7/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
Hope that helps!
Many thanks and it looks like I'll need to get one of those - but I'll probably replace the round knurled knobs by "winged" versions, such as one of those here because they should allow me to tighten them more securely than the round versions.
KR
John A
Posted 03/10/2021 - 18:15
It looks like a winged version of the top knob could hit the camera. Would a head with a lever to lock/unlock the QR plate be better?
Posted 03/10/2021 - 18:27
That's possible but the camera will have an Arcaswiss-compatible adapter, and that should hopefully raise the camera enough for a triangular knob to work OK- but "time will tell".
Posted 03/10/2021 - 19:17
https://www.amazon.co.uk/MENGS-BH-36-Panoramic-Low-Profile-Camcorders/dp/B07WG7Q...
The wings clamps can be moved to a position that suits you
Barrie - Too Old To Die Young
Posted 09/10/2021 - 23:52
Not a cheap one, but an outstanding one. Manfrotto 468MGQ6. You won't find one with a better locking mechanism, I use mine with a Gigapan Epic Pro with the K-3 and 60-250 zoom, and it's rock solid. The whole set up must weight about ten pounds, and it holds it securely. Amazing.
https://www.manfrotto.com/global/hydrostatic-ball-head-with-top-lock-quick-relea...
W.London
Many years ago, I bought a Red Snapper tripod from another member. That came with a pan & tilt head but which I then found to be a bit "awkward" to use, even though I only use the tripod very occasionally.
Therefore I now thinking (just "thinking"!) about getting a ball head to replace the existing one - so, can anyone suggest a relatively cheapish ball head that will support something like a K-3 and medium sized (possibly a short zoom?) lens, AND with very positive locks that can be easily (I have largish hands but my finger tips don't grip that well!) adjusted and locked?
TIA
