Travel Lens Advice
Posted 14/01/2011 - 19:20
I would take the 18-55 and 70-300. Leave the rest behind.
Save your money and upgrade your lenses when you upgrade your body.
Posted 14/01/2011 - 19:33
Ask a question - get fifteen different answers and end up making your own mind up.
Only you know if you can afford/want to spend the money on a different lens, and how much weight you are willing to lug, or are allowed by the airline to lug.
Posted 14/01/2011 - 19:35
I'd take the 10-20, the 50 and the 100 macro, and a brand new kx as spare body....
Posted 14/01/2011 - 19:36
Have a look for either the Sigma or Tamron 18- 200 models.
I use a Sigma 18-200 on my K110 SAMPLE LINK.
Despite the bad press they're both pretty good as travel lenses.
Cheers, HG
PPG entries.
PPG entries.
Posted 14/01/2011 - 20:42
Thanks so much for the replies.
DON'T HELP THOUGH
Decisions Decisions. Options Options.
Only one solution, open a bottle of wine
Will see if GF will carry a lens.
@Hardgravity - how do the Sigma 18-200 and Tanmy 18-250 compare?
No votes for the 18-135?
Would rather not buy a lens just for one trip...
Thinks :, maybe this will be an excuse for the next trip.
Stumps
DON'T HELP THOUGH
Stumps
K7; DA* 16-50 F2.8; Sigma 10-20 4-5.6 DC EX; DA18-55 WR; F50 1.7; FA100 2.8 Macro; DA* 60-250 F4.0; DA18-250
Posted 14/01/2011 - 22:00
Ah but will you be able to afford the next trip if you buy a new lens?
I predict another case of LBA coming on
Posted 14/01/2011 - 22:24
Nobody buys a lens just for one trip . . . do they?Would rather not buy a lens just for one trip...
Why not just take the two lenses you have covering the range 18-300mm. The gap between 55 and 70mm is negligible and not really worth worrying about, not just for one trip.
Then again, if it's a once in a lifetime journey, maybe you do need another lens to avoid missing opportunities.
Does that help? . . . I thought not.
Posted 14/01/2011 - 22:28
Mannesty wrote:
I'm pretty sure Mike-P has previously mentioned doing just that. More than once, if I'm not mistaken!
Tim
Posted 14/01/2011 - 22:52
It would help if you had indicated if this is a beach holiday or a touring holiday.
Long ago (1989) I passed through Thailand with 2 ME Supers and 3 lenses - 28mm, 50mm and 135mm. The Royal Palace in Bangkok needed only the 28 and 50mm; the Kwai Bridge and railway works with this combo and the floating market likewise, though I'd been better of with a third body using 200 or 400 ASA slide rather than the 50 and 100 Fujichrome I had loaded.
If I was going back, a bit of extra width for the Palace and the Temple of the Golden Buddha would be useful, wouldn't need any extra length for the Kwai and the ability to change ISO on the fly would be a boon for the floating market.
Didn't do any beaches or go north, so can't advise on these. The trip was a 4 night visit as part Kuoni 3 week Far East package trip inc HK, Sing, Thailand with a week in the Maldives.
HTH
HTH
Posted 15/01/2011 - 00:57
Bear in mind that whatever you take has to fit into your hand luggage along with the actual hand luggage which is in your hand luggage.
There is little point in getting the 18-135 lens (now, at least) for its WR capabilities - since the K100D isn't WR itself. Just take a non-WR lens and either a) One of those £50 'camera jacket' things or b) A freezer bag with the end cut out, which does essentially the same job Neither of these will help with humidity of course, which could (I imagine, never been there) be an issue depending on where in Thailand you're going.
Hope you can give me some advice.
This started off in my mind as a simple task; get a superzoom to take to Thailand at the end of March. Instead of the 18-55 kit, Sigma 70-300 and nifty 50, just take the new lens (and I reckon the 50 would end up slipping in a pocket as well). Sigma 10-20 and Pentax 100 Macro would also have to stay at home. Priority is to stay light!!
So, which lens?
Looking about have identified the following initial ideas
Tamron 18-200 c£190
Pentax 18-250 c£370 (discontinued but there are a couple out there)
Both older lenses and with mixed reviews. 18-250 sounds better. Is it worth twice as much??
Then I starts thinking (usually a mistake). All the glass above plugs into my old (but trusty) K100D. Am I building up a system which, whilst not obsolete, is a tad stale? I lock the credit card up – so it doesn’t run away - and take a look at the shiny new 18-135 WR! £545 ouch.
Body will be upgraded sometime (and if it was not for the trip – maybe rather soon) so would the 18-135 be a better long term bet, with K-r / K-7 etc?
Am I making any sense?
Have I missed any options? (i.e. lug 3 lenses about and save the money for a new body and “better” glass.)
Thanks for your time.
Stumps
