Advice on using the DA 35 Macro Limited
Hylas
Posted 16/01/2011 - 15:08 Link
I'm running with a compact prime kit (15/35/70) and am generally very happy with the performance of all the lenses; one slight frustration is figuring out how best to use the DA 35/2.8. I've two questions that wiser heads may be able to answer:
If you've had experience using the DA 35/2.8,
1. How do you avoid the camera hunting for focus in low-light? What do you do to prevent it from missing focus, and if it does miss focus, what is your course of action? Do you let it cycle through the entire throw until it finds it, or do you stop it and yank it back to infinity focus so it can try again?
2. If you've had any luck shooting bugs with it, how do you do it? I know one really should use a longer lens for bugs, but I've seen some pretty incredible bug shots with this lens and am wondering what good technique would involve?
Thanks for your time!
K-x with a bunch of primes (both auto and manual)
Mannesty
Posted 16/01/2011 - 15:47 Link
Welcome to the forum.
I haven't had experience of the DA 35mm Macro lens, but I do feel qualified to answer.
1: Use manual focus to avoid the hunting. This will be a problem whichever macro lens you use if you intend to rely on auto focussing. I have 50mm, 100mm, and 180mm macro lenses, and they all hunt on AF at various times. I use manual focus 100% of the time.
2: You've answered your own question. You need to use a longer focal length lens. I don't think that there is any other answer to this one.
3: If the light is too low for the AF to work, the light is too low, full stop. You generally need a lot of light for maccro work so you might consider investing in a flash setup for macro. A ringflash is an ideal beginning. Both Pentax and Sigma make good units, the Sigma being cheaper. Alternatively a manual flash with a diffuser of some kind over the top of the lens and subject works well too.
Of course, extra light in the form of a flash system for the exposure is not going to help with focussing. For that, you need a torch. Simple as, really.
Edited by Mannesty: 16/01/2011 - 15:53
Fletcher8
Posted 16/01/2011 - 16:04 Link
Hi Hylas
I am new to macro myself and can offer you some things I have learnt so far.
Most Macro shots need good light to get the results I think you are after, there are lots of options for lighting and how much cash you have spare. A good starting point is to use reflectors to help light up subjects. Off camera flash will also enable you to get some better images as you can move the light source around and bounce it off things. If you have the cash a ring flash would be a wise buy for macro. Focus wise, use manual focus to obtain better results. If you must use AF, in low light try shining a torch onto an area you want to focus on, it will provide a good staarting point. Have you try]ied focus stacking you images to get sharper images? Macro is a real learning curve, you just have to experiment and try out ideas, but as I said lighting is the key from my experiences.
If you are limited cash wise here are some DIY ideas
I have used sheets of tin foil as reflectors, they are better than nothing at all
you can buy desk lamps which will help light things up, but shadows can be a problem, you can make a light box for about £2, good for learning about light and shadows
A flash gun that you can use off camera will really help improve images
Try bouncing light up through Plastic sheets of perspex
You can also buy filters 2x 5x 10x which will provide you with some creative fun for less money than buying a dedicated macro.
I purchased a DA 35/2.8, a while ago as I managed to get one at a good price, but have now invested in a Tamron SP AF90 (Brand new £254) as I can't currently justify £490 for the Pentax 100mm WR which i would have liked.
Keep practising and look on the web for Macro tips and post your efforts OK
Fletcher8
Fletcher8.
Pentaxophile
Posted 16/01/2011 - 16:19 Link
You'll just have to be selective about what bugs you go after... try going for things like caterpillars moths and beetles. One of the nicest bug shots with this lens is of a couple of weevils mating. So yeah... get em while their minds are on other things!
Unlocker
Posted 16/01/2011 - 16:38 Link
Hylas wrote:
If you've had any luck shooting bugs with it, how do you do it?!
You've just got to creep up on them !
matwhittington
Posted 16/01/2011 - 16:48 Link
I have used the DA35 macro quite a lot and think it is (currently) my favourite macro lens. Any lens will hunt, I think, in low light, although a macro lens tends to have a much finer focus adjustment and longer travel from end to end, so the focus-hunting is accentuated on this lens. That said, manually focussing is very straightforward because it has the quickshift feature (just turn the focussing ring), or you could manually focus to get close to pin sharp and then use autofocus to finish... When using autofocus I personally find it much easier to set the AF to the rear button only rather than having it on the shutter button as well.
In terms of getting bugs - the main thing is patience and lots of practice. Follow the bugs and find out how they behave and try to predict their behaviour... that makes things easier. A spot of stealth is good too, and you could also try a bit of flash. I tend to use either hotshoe mounted or built in flash but with the power output wound down quite a lot to avoid the whole thing being blown out. I use a diffuser if I can as well. The season makes a big difference IMO too - on a sunny day in the summer, if you can find a park or a meadow with wild flowers and butterflies, the whole thing gets a lot easier...
Hope that helps
Mat W
My Flickr: link
Mike-P
Posted 16/01/2011 - 16:59 Link
The lens is actually very good with the Pentax 1.7x teleconverter.
A bit of extra length and added magnification as well.
Hylas
Posted 16/01/2011 - 19:03 Link
Thanks for all the advice, everyone! It looks like I need lots more practice to be able to reliably shoot bugs, though unfortunately it's hardly the season.
Manual focusing does seem a good solution in low light, although it's not really feasible when shooting non-macro subjects. The DA35 has only half a centimeter of focus throw between 0.5 meters and infinity, so it really snaps to the target when the autofocus gets it right, but can hunt for ages if it misses the target and goes through the macro-range on its throw. Equally, the short focus-throw in the non-macro range means I lack the dexterity to focus it manually with any degree of accuracy. I might be able to solve this by deliberately picking contrasty bits of the subject to focus on - I've tried experimenting with that a bit this evening and it's cut down substantially on the focus hunting.
Mike-P: I didn't know that teleconverters would allow the DA35 to achieve more than 1:1 magnification. How much more would the 1.7x allow, in your experience?
Don
Posted 16/01/2011 - 19:19 Link
I do shoot with the 100mm macro and love it. I use manual 90% of the time.
I tried the 50mm macro, and while it was amazing it hunted too much for my needs (my wife uses af 90% of the time).. and took it back and bought the 50 1.4 instead.
I suspect you will either get used to pre-focussing with manual, and then letting af lock on or you will be better off having the 35 2.4 for general purposes and buying the 100 for insects and macro......
womble
Posted 16/01/2011 - 22:15 Link
Low light focusing with non-macro subjects could be improved by using the focus assist feature of a flashgun such as the AF360FGZ provided the subject wasn't too far away.
K.
