To KP, or not to KP, that is the question.
Posted 07/12/2017 - 05:32 - Helpful Comment
the kp is a lot faster focusing and the grips are fine the only reason i am not keen on it is because it dosent have a top screen like the k3ii if thelack of top screen didnt bother me it would be buy one in a heart beat instead off the k70
Posted 07/12/2017 - 06:23 - Helpful Comment
I would go and hold one first. I didn't like it because it didn't feel right.
K3, K3 II, 100MM 2.8 Macro, Sigma 10-20 3.5, Sigma 17-50 2.8, Nikon D7500, Tamron 150 600 G2
Posted 07/12/2017 - 07:50 - Helpful Comment
Have you considered buying a used k3 ?
A lot cheaper than either of the other 2 options, with money left over to spend on lenses.
Posted 07/12/2017 - 08:22
No IR Remote on the KP and it smells of salted peanuts
Both need a non standard jack on their remotes..... Big minus as Sony found out when they tried to change their hot-shoes
Posted 07/12/2017 - 11:19
Sony should have put gloves on befor they tried to do that
Posted 07/12/2017 - 12:27 - Helpful Comment
Dont want to complicate things. But I too think the K3, K3II should come into the equation.
Stuart..
Stuart..
Posted 07/12/2017 - 19:39 - Helpful Comment
It may be worth trying this fix for your K50, it does not involve opening the camera and you have nothing to loose in trying. Ive not needed to try it.
https://www.dpreview.com/forums/thread/4221791#forum-post-60341237
I have the KP and love it, its great using it with LTD lenses, The extra dial and the flip screen are good too. It does everything the K3 does and some things like the shake reduction are imporoved. The camera is small in the hand so it is worth considering what type of lenses you will use with it. It does not feel as comfortable with Larger lenses as The K3 or K30 did, using the largest grip helps in theses cases but ist not as big as the K3-K30/K50.
Posted 07/12/2017 - 22:31
Thanks for the advice, but it is too late for my K-50. I sold the body and everything that came with it in the original box (except the 2 lenses, 18-50 and 50-210) to someone on ebay for $93. Maybe they can fix it. Oh, I also included the little AA adapter and the e-book that I bought. As for lenses I'll use, I'll use the two above plus a variety of other Pentax lenses that I have, from M42 to k mount MF to other autofocus lenses. The biggest and heaviest might be some 135 and 200 mm m42's and an autofocus 70-300mm.
Posted 07/12/2017 - 22:33
That's a good point, and I did think about that. I think the k3 has a flash, right? I'll look at it again.
Yes, I'll look at both again.
Posted 07/12/2017 - 23:38 - Helpful Comment
Yea the K3 has a pop up flash.
K3ii doesn't, I didn't mention the k3ii because I felt the lack of a pop up might be a deal breaker.
Happy hunting.
Happy hunting.
Posted 08/12/2017 - 01:21 - Helpful Comment
If your considering serious photography !! You will use a full size flash gun. The pop up flash is pretty much useless. Except as a flash trigger for other flash units or in an emergency situation...
Stuart..
Stuart..
Posted 08/12/2017 - 05:53 - Helpful Comment
I will be selling a K3 II shortly, low shutter count, in case you are interested.
Posted 09/12/2017 - 04:50
No, I disagree, the pop up flash is not pretty much useless. The pop up flash is quite useful for some fill-in flash in bright sunlight, for example. I have a great AF360FGZ P-TTL flash, but I'm certainly not going to lug that around while I'm out and about in most cases. I'm not a professional who goes out just to take pictures, with a big bag of gear and maybe an assistant. Sometimes I go out just to take pictures for fun, sometimes I just grab the camera and bring it with me when we go out for a family trip, and sometimes it is something in-between (balancing "real life" activities and including some "just for photography sake" effort). Using all of your available tools in appropriate ways and at appropriate times is by no means an indication that someone is not "serious" about photography. There is not one way to take good pictures, nor just one type of equipment to use.
10 years
Near Chicago,
Illinois USA
Plus and minus for the K-70:
+ Similar in handling to the K-50, which I really enjoyed for ergonomics
+ Overall value of the body, plus the value of the discount on the 18-135 when purchased with the kit.
+ More powerful built-in flash (GN12). I know many people dislike built-in flash, but I definitely want one and was always pleased with the K-50 flash which had equal power.
+ Better autofocus during video (I don't do much video, but this seemed like a good feature).
- On-board flash no longer serves as a wireless controller (I own a AF360FGZ flash, but I rarely used this wireless feature. But still, why take that away when the K-50 had it?)
- Less autofocus and exposure points (though I never had a problem with the 11 points on the K-50).
- Perhaps of more substantial concern - I just can't find a definitive answer to the question as to whether or not the K-70 might suffer from the same aperture solenoid issue as the K-50 as the units age in the marketplace.
Plus and minus for the KP:
+ Supposedly higher quality construction. I don't care too much about magnesium vs. plastic, but if this means the shutter won't have the aperture problem, that is a definite plus.
+ Better specs on autofocus, exposure points, and high ISO
+ Flash can server as wireless controller
+ Extra control wheel and more customization on controls. Though the two wheels and the green button on the K-50 were just fine for me.
- Rear screen not fully articulated (never had a camera that was fully articulated, so not sure how important this would be. Tilt is handy though.)
- Flash under powered at GN6. Though, with the higher ISO capability, maybe this is not a problem? Any opinions on this?
- Heavier. I do value light weight.
- Maybe the biggest: The "retro" look doesn't do much for me. And I'm quite concerned about the grips. Even the larges of the interchangeable grips is much smaller than the grip on the K-70. I loved the grip and handling of the K-50, and the K-70 is very similar. I'm afraid I won't like the KP nearly as much. And I've read many people suggesting you could switch out the grips depending on lens used, but I don't want to bother with that.
So my thinking has gone from K-70, to briefly deciding on the KP, then back again to the K-70. Should I change my mind again?
