TDF Stage 1
Posted 01/07/2014 - 19:26
Not listening, not listening, not listening
Posted 01/07/2014 - 19:39
Excitement! Great opportunity Carl - the only thing I know about aerial photography, and helicopters in particular, is vibrations and movement. So the 'priority' (good word) is shutter speed. If you go for P mode, then make sure your 'program line' setting is on 'fast' (it has a running man icon). This should push things in the right direction.
But these program algorithms are never aggressive enough IMO, usually choosing a middling course, so I'd take control I were you and keep a highish ISO - 800 or 1600 on that camera should be fine, choose a wide aperture lens (maybe f2.8 maximum would be OK?), then use Tav and set ... I don't know, what does everyone think?.... around 1/1000th sec or so to keep sharp shots?
Posted 01/07/2014 - 20:21
Sounds like a life time one off Carl, enjoy the day and let the photography take second place.
Half tempted to set the K5IIs to 'auto' and get 'averaged' shots rather than risk messing up in the heat of the moment - any thoughts on the pros/cons of this approach?
TAv, =>1/1000 and let the camera do the rest.
Brian.
Brian.
Posted 01/07/2014 - 20:28
I would make sure I had a good compact with me for the flight. Aircraft are very tight and no place for telephotos and zooms. Unless they don't have doors!
And you might be restricted on weight.
In fact getting anything better than a snapshot takes a lot of skill.
Posted 01/07/2014 - 20:43
Hi Carl
I will keep a lookout for you has I hope to be around Leeds at about 8-00am
cheers Neil
pentax k3
Panasonic Dmc Fz200
pentax k3
Panasonic Dmc Fz200
Posted 01/07/2014 - 21:17
Good idea Gareth - will stick the Q in my pocketI would make sure I had a good compact with me for the flight. Aircraft are very tight and no place for telephotos and zooms. Unless they don't have doors!
Carl
Posted 01/07/2014 - 21:18
gtis wrote:
Hi Carl
Hi NeilHi Carl
If I bump in to you - will try and smuggle you in to the VIP area for a bacon sarnie - have a good day!
Carl
Posted 01/07/2014 - 21:19
Nigel/ Brian - Tav 1/1000th makes sense - good idea
Carl
Carl
Posted 01/07/2014 - 22:32
Give us a wave when you fly over the Ilkley / Addingham stretch
I am wondering if I'll be able to cycle from Ilkley across to Harrogate to catch the end of the race on the Stray. The main roads will be closed until late afternoon and the back roads will most likely be chock-full of traffic. Let me know if there's a spare seat in the back of the helicopter..!
Looking forward to any pictures you get to take, but most of all I hope you enjoy the day.
Nigel.
Posted 01/07/2014 - 23:17
Thanks NigelGive us a wave when you fly over the Ilkley / Addingham stretch
Roads are going to be a real problem. I live in Scotton, a couple of miles from Knaresborough and all the roads around me are closed - still trying to work out how to get to Leeds on Saturday and York on Sunday.
For you - certainly can't get in via Skipton Road and A59 is closed. I think you may be OK if you go down the 658 from Poole and then take the back road to the left - forget the road name - goes through Leathley to Beckwithshaw - and then cut in to Harrogate on Otley Road - towards Harlow Carr - don't think that route is closed.
Train appears to be my only option but that will involve a 3 mile walk to Knaresborough station.
Carl
Posted 02/07/2014 - 12:08
I've done a lot of work from helicopters both stills and video but always with a door off. To give you an idea, on one job we hired the aircraft for two weeks and used the camera mount that had just come off a 007 movie. So long as you aren't leaning on the aircraft you won't have any problems with vibrations. Depending on the aircraft best place is on the starboard behind the pilot because a helicopter naturally turns smoothly in a clockwise direction if you are planning on going around the action. Turning the other way can be pretty choppy. It may be you will be limited in manouevering due the other aircraft in close proximity of course. I can't imagine you will be limited in any way by the weight of your equipment. I cant see any use for the 10-20 unless you want to snap the pilot. I would go for 1/250 on Tv for starters
Posted 03/07/2014 - 00:56
Carl
Certainly, the back roads are the way to go. Leathley is on one of my regular routes and I just hope nobody else has the same idea. Fat chance!For you - certainly can't get in via Skipton Road and A59 is closed. I think you may be OK if you go down the 658 from Poole and then take the back road to the left - forget the road name - goes through Leathley to Beckwithshaw - and then cut in to Harrogate on Otley Road - towards Harlow Carr - don't think that route is closed.
Carl
Is the helicopter not picking you up on Saturday? Plenty of fields your way to set down
Just checked the weather forecast - it should be perfect flying weather during Saturday afternoon.
Due to work pressures I missed the Ilkley town centre racing on Tuesday and the racing in Otley on Wednesday. By all accounts the Ilkley races were a good spectacle. I do have a generous boss though as he is taking us to the opening ceremony at the Leeds Arena
Nigel.
Posted 03/07/2014 - 07:57
Hadn't thought of that Nigel - there is a nice flat field next to our house and the paddock where my wife keeps her horse across the road - that would do nicely Is the helicopter not picking you up on Saturday? Plenty of fields your way to set down
My wife - ever helpful - has offered to lend me George (what sort of name is that for a horse?) as the bridleway to Knaresborough will not be closed
Carl
Knaresborough,
North Yorks
Just received my itinerary:
9:00am: Access to “Village Depart” program Leeds Millennium Square
11:30am: Departure on the race track before the riders in the official VIP Car
12:00pm: Official departure of the race
1:00pm: Picnic basket lunch, transfer to the Helicopter departure zone & flight over the race
3:30pm: Arrival at the VIP area located near the finish line with open bar and entertainment
4:00pm: Stage finish with a celebratory champagne cocktail
I wonder how much gear I can carry in the helicopter
Have also been asked to host the event for my company at the start of stage 2 on Sunday at York race course including introducing VIP guests to riders - access to the Teams village etc
I need to be careful how much gear I take so shall be limiting myself to the K5IIs, 10-20 plus 17-70 or 50-150 and may slip the 35Ltd in a pocket
Carl
