tamron sp 90
reso
Posted 30/07/2011 - 16:15 Link
started to use this lens today veiwfinder dark at f 2.5 taken photos of a few plants on our balcony 2200 asa can only get f4 or the shutter speed is to slow also set -1.5 have i got a duff lens/mount seens to take beter pic.s in spot mode advice please
reso
Posted 30/07/2011 - 16:40 Link
just had the mount wide open at 2.5 veiwfinder lovely and bright moved it to 32 ae blades shut veiwfinder dark blades dont seam to move when photo taken is this a mount fault
Edited by reso: 30/07/2011 - 16:41
Pentaxophile
Posted 30/07/2011 - 16:41 Link
Viewfinder should be bright at f2.5. Sounds like the iris is closed right down.
Are you using a PKA mount? Is lens set to the 'AE' position?
What happens if you set it to f2.5 on the aperture ring?
Edited by Pentaxophile: 30/07/2011 - 16:47
Pentaxophile
Posted 30/07/2011 - 16:44 Link
The iris should close down at the AE setting when the lens isn't mounted, but when mounted to the camera, a little lever on the lens mount will open the iris up and will keep it open until the shutter fires. Or should do!
Edited by Pentaxophile: 30/07/2011 - 16:45
reso
Posted 30/07/2011 - 16:49 Link
the lever is not keeping the iris open?
Edited by reso: 30/07/2011 - 16:50
Pentaxophile
Posted 30/07/2011 - 16:51 Link
I think it ought to... when you press on it with your finger you should see the lens open up.
reso
Posted 30/07/2011 - 16:53 Link
just taken of the lens and it will open with my finger
but not when on the camera?
reso
Posted 30/07/2011 - 17:07 Link
sorted the leaver was very close to the metal guard thing moved it over a bit to give it more of a cap so works ok now thanks for your help
phill
