Superglue
coker
Link Posted 17/12/2021 - 12:34
Setting my focus manually for my macros was becoming more difficult, aligning a black insect pin with half-degree accuracy.....
Ah, I know!
What I need is a v. small magnifier/lens to "enlarge" the needle-point/degree marks.
Amazon didn't seem to have anything suitable, so I thought...
I'll make one!
I put a bead ( about 10 mm. diam.) of superglue on a mic. slide. This sat up nicely in a hemispherical shape, just like a lens, in fact!
I let it "dry" for about an hour, then thought that it could be higher, so put another couple od drops on & left it to do its thing, i.e. set.
When I next looked, it was as though the (glass-clear) drop had curdled, crystallised.....
Onto the macro set-up & this was revealed.......
Thoughts, anyone?
Explanation?
Magic?
Thanks for looking,
Roger.
Chrism8
Link Posted 17/12/2021 - 13:21
Defiantly magic , superbly well shot and the BW conversion suits it perfectly.
Chris
Samyang 14mm F2.8, Pentax DFA* 70-200 F2.8
Link Posted 17/12/2021 - 13:46
..and a piece of art in its own right - excellent!
Urbanmeister
Link Posted 17/12/2021 - 14:38
How intriguing is that? Lovely image, coker.
Be well, stay safe.
LongTimeLurker
Link Posted 17/12/2021 - 17:29
Another excellent photograph.
It looks like you've discovered a new lifeform.
Nigel.
coker
Link Posted 17/12/2021 - 18:26
A comment made to me:
"Wow! Almost looks like a biological structure! It really shows the intrinsic link between chemistry and biology. No use as a lens though."
(Coker)
alfpics
Link Posted 17/12/2021 - 19:04
Amazing - whatever is going on!
Andy
Flan
Link Posted 17/12/2021 - 19:47
would be a great album cover in the psychedelic rock era
Fascinating to look at
Lubbyman
Link Posted 18/12/2021 - 19:17
Stunning, original and very well seen and taken . How many times have I seen a blob of glue go cloudy and never thought about what's actually happening blob...
As for an explanation, it might be due to air trapped under the second blob trying to work its way out while the glue sets. Alternatively, it might be due to the glue setting from bottom up and top down simultanously. Apparently, superglue starts setting when exposed to moisture, even moisture in the air is enough. Once started, molecules of glue start to join up (polymerisation). Moisture in the air would start top-down setting, tiny areas of moisture or not completed polymers on the surface of the first (lower) drop could start bottom-up setting. If top-down and bottom-up setting produce polymers that are optically different (e.g. due to being different lengths), the interface could be visible. Or the true explanation might be none of the above...
OK, I'll go back in my hole...
coker
Link Posted 18/12/2021 - 23:05
Yes.
What I said.
Magic!
Thanks all for looking,
Roger.
pschlute
Link Posted 22/12/2021 - 20:44
Love it
