Stu Stu Studio kit
Posted 06/03/2009 - 09:47
Interfit do a home studio kit at £299 that looks fine. Then you only need a background.
Posted 06/03/2009 - 11:09
Jessops have a couple of Portaflash mini studio kits on their clearance lists
http://www.jessops.com/content/services/clearance/pdf/121_v7.pdf
Cannot pinpoint what they comprise, but I'm sure Phil at New Oxford Street will have a nose for you....
K20D and a substantial user manual to wade through
Posted 06/03/2009 - 14:21
Thanks guys. that Interfit kit looks promising John - certainly a good starting point.
Diatribe, the Jessops kits are for product shots but thanks anyway. If anyone is looking for a two lamp kit with a transparent base/background then check it out.
Posted 06/03/2009 - 16:21
I do video work as well as Photography.
I had to upgrade the modelling lights on my studio strobes, to use them with video.
If I had to start today, I'd go hotlights or cfl for studio and p-ttl flash units for location...
Posted 06/03/2009 - 17:27
Don have you never thought of using Kinoflos, I use the Diva-Lites quite often. They are low-profile, lightweight, cold, constant and accurate white balance. Although I find the colour temp a bit extreme so if I'm using tungsten tubes I will mix 3 tungsten with one daylight and vice versa. If you dont know them check them out here link
Plymouth,
UK
I have £3-400 to buy some sort of portable studio. I may do some video very infrequently. But mostly still portraits and I probably shouldn't rule out family shots.
I am toying with one of those pop-up backgrounds with a train, two soft boxes, a hair light and a multi-colour reflector.
The main queries are:
Flash or new-fangled low wattage continuous lights?
Soft boxes or umbrellas?
Any clues as to the best place to look? (it's a minefield out there)
Plymouth Photographer
