Squirrel
ElRazur
Posted 26/09/2010 - 16:57 Link
Okay, so it is a Gray squirrel. C&C welcome.
Minor editing done - Played with colour curves, hue and saturation and a contrast. Plus a bit of cropping.
[IMG]http://img228.imageshack.us/img228/3075/squireleditedcopy.jpg[/IMG]
08tiger
Posted 27/09/2010 - 07:56 - Helpful Comment Link
Cheeky devil, is that a spud it's got between the teeth.
i-Berg
Posted 27/09/2010 - 08:49 - Helpful Comment Link
I'll comment on two aspects with suggestions, El - the crop might be improved by way of a portrait orientation to eliminate some of the space on the LHS?
The second was that the image may benefit from adjustments that make it lighter and brighter?
fatspider
Posted 27/09/2010 - 12:43 - Helpful Comment Link
You need to do something with that very bright area above the squirels head, is it blown out on the original?
The eye is always drawn to the brightest part of an image and this one is really distracting from the subject.
My PPG link
My Flckr link
TOZZA27
Posted 27/09/2010 - 13:09 - Helpful Comment Link
Cracking shot - looks like he`s/she`s got a horse chestnut - mine even wait for me to open them as they are so lazy !
I don`t agree with the cropping suggestion and although the light patch is not perfect - there is sufficient happening to keep the eye on and leading to the subject.Nice colours too complementing the season and the shot.
Tony
ElRazur
Posted 27/09/2010 - 14:00 Link
Thanks guys. Here is the original one - as shot. (See below)
I used a high ISO, so I am not sure if that counts for why the white bits appears blown out?
Thanks for all the tip, I will fire up PSE and do the adjustments on the lights.
[IMG]http://img178.imageshack.us/img178/3018/onatree.jpg[/IMG]
(Image quality just scaled down on this one)
fatspider
Posted 27/09/2010 - 18:00 - Helpful Comment Link
Having seen the original theres not much you could have done about it, Just one of those situations where the camera does its best to get the exposure right, you have the problem of a dark tree trunk and a bright sky, so the camera has done pretty well.
My PPG link
My Flckr link
amoringello
Posted 27/09/2010 - 22:24 - Helpful Comment Link
Cannot disagree with anything said, but if you want to get some of that color back it is a 30-60 second fix to change the white background to a decent blue. Dunno if PSE allows for different draw modes, but hopefully the following will work for PSE
Pick up the brush tool.
Set the brush to about the color of blue you want.
Set the draw mode to "Darker Color".
Set Opacity to 50%
You now just paint roughly over the white. No need to be too careful.
Anything lighter than your brush color will go blue. Everything darker will stay untouched.
The gray twigs wil remain visible even if slightly lighter than your brush since you're only at 50%.
Dab over some areas with the Blur brush if the color transition is too rough and you get sharp edges appearing.
OK, this doesn't work in all cases, but it seems to work well on this one. (and no need for pesky masking , where even with CS5 can take a few extra minutes).
Edited by amoringello: 27/09/2010 - 22:25
puma
Posted 28/09/2010 - 20:52 Link
i like the original one what a great photo
PPG link
ElRazur
Posted 29/09/2010 - 18:38 Link
Set Opacity to 50%
Thanks man. I will definitely give that a try.
