Soligor 400mm f6.3 M42
I don't know that lens but I do have an old NPS 400mm m42 lens - I have a set from it on flickr.
Pictures from the NPS have low contrast, however, by tweaking the blacks and contrast on the raw files pictures come out pretty well - mine is best at f8 to f11 and are really helped by the use of a lens hood.
Whilst they are not the same lenses the above advice may or may not help but I hope it does.
Best used with a monopod or tripod though.
Stu
I've used it on the K10, K20 and on the K5 with a Pentax 2x TC - interesting that!
Incidentally, as with the DA300 and Bigma variations, unsupported it's probably heavy enough to pull the front off the K digital
Roger
Although the lens appears to be in good condition optically, its former owner in his infinate wisdom decided to paint it green & brown to camouflage it. I don't know why, he just did. Some paint seemes to have seeped in and has unfortunately made the auto/manual ring impossible to turn. It's stuck on auto so I'm unable to select anything but full aperture. Before I try to turn it with a bit more force, could someone confirm there are no locking buttons preventing me turning it. I can't see any but there's always chance one has fallen off.
Many thanks again.
There are no locking buttons for you to worry about. Just in case you are not aware, the front (chromed) ring is not connected to the aperture mechanism, the rear (black) one is. Choose your aperture on the front ring and the rear enables you to switch between the chosen aperture and f6.3 for clearer focussing. Obviously the rear ring cannot be set to a smaller aperture than that indicated on the front ring but both rings rings can be moved together.
So gently does it
Does the lens still focus OK?
Roger.
cheers
bb2
K5, K20D, Bigma, Sigma EX 105, Sigma EX 10-20, Sigma EX 28-70 F2.8, Sigma Ex 1.4TC,
Pentax 135 F3.5, Pentax 30mm F2.8 , Pentax 50mm F1.7, Pentax 55mm F1.8,
Super Taks: 35mm F3.5, 50mm F1.4, 135mm F3.5, 200mm F4
Vivitar TX 200mm F3.5,Vivitar (Komine)135mm f2.8, Vivitar 2X TC, Vivitar T4 400mm F6.3
Tamron SP 35-80,80-210 F3.8, Helios 44M, Mir 1B 37mm F2.8, Jupiter 9 85mm F2, Chinon 28mm F2.8, 3M-5A 500mm F8 etc etc
Oh - and the M42 mount (which is held in place by three tiny grub screws)tends to work loose and the lens invariably turns up-side-down just as one is about to set the aperture..
Would some kind of Loctite on the grub screws help, or is there too much risk of that getting somewhere it shouldn't?
Staffordshire,
England
A friend clearing out his loft has generously given me an old Soligor 400mm f6.3 lens in M42 mount. It is in pretty good condition. Has anyone any experience of this lens? Is it worth using with my K10D and K-5?
Many thanks.
