Solar battery chargers
Sitav
Posted 01/05/2008 - 22:10 Link
Has anyone had any experience (good or bad) of solar battery chargers? I've been looking at a few, there seems to be quite a price range and varying models from simply a solar panel outputting 12v like this one to more sophisticated (heavier) varieties which house there own battery as well like this one
They seem potentially quite handy depending on charge time etc.
Classvino
Posted 02/05/2008 - 14:46 Link
Though costing a bit in terms of weight to lug around, the built-in battery makes the second a much more versatile unit - and half the price of the other as well...
MZ-6,K10D,K20D,Grip,DA*Zooms,DA 18-55-200 Kit,FA50,1.7TC,AFZ360
For Saleentax FA28-90,FA100-300,Sigma EX28-80,DC18-200,
Makinon 500mm Mirror
Bob and his Pentax
Posted 02/05/2008 - 16:01 Link
I think you need to remember that what ever solar panel you use you still need an attachment that allows you to charge your (camera) batteries and the output from the charger (wattage) must exceede that of the battery in order for charging to take place.
Also the exernal power supply to Pentax DSLR only powers the camera but does not charge the battery and you would need to convert from the battery voltage to that needed for the camera.
The 'FreeLoader' has the advantage of its own battery but its limited capacity. The 'Silva' unit has desent power output but no storage.
Heres the system I used whilst camping for 3 weeks at the Scouts World Jamboree last year.
- 12V 10W Solar Panel (but remember thats peak output in strong sun)
- regulator to prevent battery over charge
- small sealed 12V Lead Acid battery (10AmpHour)
- 4 way 12V car socket
all purchased from Maplin Electronics (http://www.maplin.co.uk/)
During the day I charged up the battery at night I charged up 'devices' from the battery. At night power from the 12V battery charged up my mobile phone, IPAQ pocket PC, batteries for IST *DS, batteries for K10D, portable storage disk/cardreader.
The hardest thing to find of this setup was a 12Volt powered charger for the K10D battery - eventualy I found the Hahnel Power Station Ultima (in Pentax flavour) does it.
Other devices which were not 12V and did not have thier own 12volt power leads I converted to the voltage stated as the output on their 230volt chargers by using 12V step down plugs also from Maplin.
This set up was estential to my job at the Jamboree as I was one of the 20 Official stills photographers and this kept me going for over 80GB of RAW pictures.
Expensive? yes but still cheeper than buying sufficient DLI50s to keep me going for for 3 weeks.
I would say that if you just want to power a phone the get the FreeLoader. Otherwise (of these 2) I would get the Silva as it could be used either directly onto a device (eg camera batery charger) or could charge a small auxilliary battery to allow camera charging later. Its small enough to strp onto the outside of a rucksack if you are backpacking too.
Put please dont plug the 12Volt solar panel / battery directly into your DSLR (unless you want a good excuse to buy a new one of course)
Bob
Good luck
Bob
Daniel Bridge
Posted 02/05/2008 - 23:19 Link
You didn't by any chance come over to the Walled Garden in Bedfords Park did you? Had about 1000 scouts through over a week, did an amazing job of clearance there. They also contributed to a mural there, handprints around a central logo.
Dan
