smc DA* 16-50mm Focus Issue
NigelMe
Posted 27/03/2010 - 08:35 Link
My 16-50 is playing up. It does not seem to AF when the camera (K7) is first switched. After some time (maybe 10 minutes), it starts working normally. I have cleaned the contacts but this has made no difference. Other lenses (including SDM) work as expected. Anyone else had this kind of problem? Anyone know how long the (UK) warranty period is on DA* lenses?
Nigel
Anvh
Posted 27/03/2010 - 09:22 Link
2 Year if bought from a pro dealer.
From what I understand there are also laws in the UK that a product must "satisfy", with that I mean a DA* lens is a high quality product so with normal use it shouldn't break down after 3 years, at least that's your expectation.
Stefan
K10D, K5
AF-540FGZ
Posted 27/03/2010 - 10:02 Link
In the UK there is the possibility of claiming for faulty goods up to six years.
Should a lens last 6 years? I would expect it to last a lot longer than that.
However, in the first instance that 2 year Pro Dealer Warranty looks like the first step.
NigelMe
Posted 27/03/2010 - 10:18 Link
Thanks all. Bristol Cameras do not appear to be a Pro Dealer so I guess 1 year warranty applies. I will make sure Pentax are aware of how disappointed I am!
Posted 27/03/2010 - 10:26 Link
You don't have to give up there. Visit your local Citizen's Advice Bureau and they will be able to tell you how to proceed. You should get an amicable resolution to this.
GlynM
Posted 27/03/2010 - 10:27 - Helpful Comment Link
NigelMe wrote:
My 16-50 is playing up. It does not seem to AF when the camera (K7) is first switched. After some time (maybe 10 minutes), it starts working normally....
This sounds just like the problem I had with my first DA*16-50 and I think my 3rd is going the same way.
The first one, on a K10D was very sticky. The auto focus would just move a little bit and then stop. Manually moving it several times, or putting it on a non-SDM body (I used a k100D) and doing some end-to-end focusing would un-stick it and then it would work fine for a couple of days. After a month or so of this I got to the point where I could not trust it so sent it back and got a replacement.
I'm now on my third DA*16-50 and using a K-7. This one is also causing similar problems. It seemed to start with an earlier firmware upgrade to the K-7. Often the auto focus does not move and also, occasionally, the K-7 does not light or flash the focus hexagon in the view finder. Other times the the lens does not move and the hexagon will flash to indicate that the focus has failed.
To get it going I often put the lens cap back on, manually set the focus to minimum distance (0.3M) and then try some auto focusing. The lens should swing from min to infinity focus and and come in a little. It seems to take a few attempts to unstick the lens focus and then it seems to be fine for a few days.
I'm not completely convinced what the problem is with this 3rd lens. Sometimes when it sticks without flashing the focus hexagon I point it at a bright, hi contrast, subject and it all comes good. I therefore think that there may be 2 separate issues, sticky focus motor, and some issues with the K-7 firmware and that the two can interact.
I still have a few months guarantee on this lens so I'm just waiting to see if it gets any worse. Certainly with the first one it took some convincing to get a replacement as once it was unstuck it would be fine for a couple days.
Hopefully yours is still under guarantee. My recommendation would be to try the test with the lens cap on to prove that it is a sticky SDM and get it replaced or fixed.
My experience with these lenses has put me off buying any other SDM lenses. I don't have confidence that they will have the longevity of the older screw-drive lenses. While I know you can probably get them fixed I just don't want the hassle.
Glyn
Edited by GlynM: 27/03/2010 - 10:41
Mike-P
Posted 27/03/2010 - 11:36 Link
If you bought it with a credit card then check with them, mine gives an extra years warranty on anything I buy which is why I always use that one for large purchases.
royd63uk
Posted 27/03/2010 - 12:01 Link
yikes i just bought an sdm lens!!!!!
regards
Roy
Pentax K3 gripped,and some lenses
https://www.flickr.com/photos/pentaxroy/
my pbase gallery
Mike-P
Posted 27/03/2010 - 12:23 Link
As long as it wasn't the 16-50mm or 60-250mm you will be fine.
It would be handy if Pentax would allow us to choose SDM or Screw drive via the menus .. at least we could carry on if SDM fails. (apart from the 17-70mm and 55mm of course)
Edited by Mike-P: 27/03/2010 - 12:25
Anvh
Posted 27/03/2010 - 12:57 Link
Also the DA*60-250, i knew the DA*16-50 had major problems in the beginning but that seems to go better now and the DA*50-135 also had problems...
Pentax already said that developing the KAF2 lens mount (SDM+Screwdrive) was expensive and complicated, it might be that the dual-drive have caused some problems, haven't heard about a lot of problems with the DA17-70 or DA*55. At least they have not to use the mount anymore on upcoming lenses.
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 27/03/2010 - 12:58
royd63uk
Posted 27/03/2010 - 14:22 Link
regards
Roy
my pbase gallery
Mike-P
Posted 27/03/2010 - 14:33 Link
royd63uk
Posted 27/03/2010 - 16:30 Link
you are devil....
regards
Roy
my pbase gallery
Greytop
Posted 27/03/2010 - 17:18 Link
Very slightly off topic, I'll just chip in and say that I had both the 16-50 and the 60-250 (now Roy's lens) and neither SDM has missed a beat. So it's not something you should overly concerned about.
And Roy you do have plenty of warranty left on yours
Regards Huw
flickr
Edited by Greytop: 27/03/2010 - 17:18
royd63uk
Posted 27/03/2010 - 18:04 Link
regards
Roy
my pbase gallery
