Slave flash.
Father Ted
Posted 08/10/2008 - 16:02 Link
Seeing as I am on a (very) limited budget, I was looking at one of THESE to compliment my camera's flash.
Are they any good?
hefty1
Posted 08/10/2008 - 16:15 Link
You can't fire them with the built in P-TTL flash of a DSLR as they'd be triggered by the pre-flash (which you can't turn off). You'd need a "dumb" flash to sit on your camera's hotshoe to act as a trigger - you can get one on eBay for a couple of pounds generally.
Joining the Q
stevejcoe
Posted 08/10/2008 - 16:18 Link
From my experience they can be a bit hit and miss. Working on manual mode with no pre-flash seems to work best with the K10
I will sell you mine(boxed with instructions)for £7.50 including postage and packaging.
If you are interested send me a pm
Edited by stevejcoe: 08/10/2008 - 16:18
Father Ted
Posted 08/10/2008 - 16:34 Link
Thanks guys.
I've been wary of getting the older flash units off ebay as I've heard they can damage the camera.
I've still got my old "dumb" flash I used with my Super ME and thought of using that, but I was too scared
Thanks for the offer Steve. I might yet take you up on it...if I can find a suitable dumb flash!
womble
Posted 08/10/2008 - 21:27 Link
On MattMatic's advice I picked up a AF160 on eBay for peanuts to trigger my AF360FGZ in slave mode. Works a treat, MattMatic strikes again
By the way, ebay has one of those slave flashes currently going for a penny... 260296853212
Best wishes, Kris.
Posted 08/10/2008 - 21:58 Link
Cool
Just to clarify Kris' comment. The AF360 supports two slave modes - P-TTL "intelligent" slave mode, and "dumb" slave mode. Incredibly useful. I started using the AF360 as a slave to a Canon S30 compact digicam
Father Ted
Posted 08/10/2008 - 22:27 Link
Thanks guys.
I'm now watching an AF160 on ebay. Don't tell the Mrs
hefty1
Posted 09/10/2008 - 00:08 Link
I got this little beauty for a fiver - mint condition (with handbook), tilt and swivel, hotshoe and PC cord, manual and auto operation, guide number 32 (so just slightly less than the 360). Very happy with it and it triggers the 360 a treat
[IMG]http://i223.photobucket.com/albums/dd37/hefty1969/IMGP3510.jpg[/IMG]
Joining the Q
Father Ted
Posted 09/10/2008 - 10:11 Link
Just found THIS page with flash voltages, if they are of any use to you.
Also, just won a Canon 200E flash on ebay for £3.64 inc postage. Got to be worth a gamble for that price. It might not be all singing all dancing, but it's a start.
Clarky
Posted 09/10/2008 - 10:42 Link
Just on flash voltages, I got to have a look inside a dismantled K10D and noticed the flash capaciter (Is that what you call it?) Its what looks like a AA battery and is used for storing the charge for the flash.
Written on it is 330volts, so I am assuming that is the max discharge of the flash. I would expect then that 330volts is the max trigger voltage a K10 can handle before it harms the camera.
Matt will probably be able to shed more light on it than I. (no pun intended)
Camera:|K-7|
Posted 09/10/2008 - 11:15 Link
Clarky,
You are partly correct... yes, flash tubes typically discharge at around 300V DC (just don't whatever you do touch the capacitor! It'll surprise the life out of you )
However, the capability of the hotshoe sync voltage is another matter entirely. In the "good old days" when cameras were clockwork, the flash pin was shorted to the camera body with a simple mechanical switch - so sync voltage was almost unimportant. With modern cameras you do the switching with electronics - and this is where there's variability in what can be supported!
Canons apparently handle up to 6V. Put any more than that and you pop their hotshoe discharge circuitry . Nikons can handle three or four hundred volts on the D300 (it's mentioned in the manual - can't remember the exact figure). Pentax is solidly built too offering maximum support with older units.
You'll never tell from looking inside the camera... unless you know exactly what you're looking for (and even then you might not find it!!).
There's a lot of worry about this - but I've never heard of a Pentax dSLR being popped by a flashgun!
Clarky
Posted 09/10/2008 - 11:24 Link
Thanks Matt I knew you would enlighten me
Thats useful info cheers
Camera:|K-7|
Mannesty
Posted 09/10/2008 - 11:41 Link
Father Ted wrote:
Thanks guys.
AF160's are cheap but to use it as you intend, it will always contribute light to the scene.
A better solution is to choose an older flash that has tilt/swivel capabilities. When the head is pointed straight up, your subject will not be illuminated by direct flash and your AF360/540FGZ will still trigger.
All this assumes you are inside so that some bounced flash is received by the AF360/540FGZ to trigger it. This may not work so well outside in an open space.
Edited by Mannesty: 09/10/2008 - 11:42
Posted 09/10/2008 - 12:56 Link
Don't forget you can always reduce the amount of light - attach some tissue paper with an elastic band for example. Admittedly it will always contribute, but not by so much
When I used the AF160 with the ME-Super/MEF I cut a little piece of black insulation tape and had it covering the main tube of the AF160. Definitely reduced the amount of glare, and it became a permanent fixture!
Father Ted
Posted 09/10/2008 - 13:12 Link
I have lots of opaque white platic in the garage ( vegetable oil containers for the car ), so I will have a play with these, making various diffusers. See how that works.
