Single focus lenses 2017
Posted 23/06/2016 - 21:11
There's not a lot of detail on it yet so anyone's guess!
If it helps anyone here's the link to it:
http://www.ricoh-imaging.co.jp/japan/products/lens/images/K_Mount_D_FA_Lens_Road...
Posted 23/06/2016 - 23:07
I'd be most interested in a fairly wide prime lens, perhaps about 20mm.
Posted 24/06/2016 - 18:59
I do not see the important "AW" or " WR" in the lens description.
Time yet for clarification or
To inform Ricoh of our thoughts.
Regards.
Regards.
Posted 25/06/2016 - 07:59
Regards.
That's because it is a generic description, without aperture or focal length either. And the map doesn't include the latest compact zoom so maybe there will be more surprises; seems to be the Ricoh way to give long range teasers and then new products out of the blue.
Regards.
Posted 02/07/2016 - 00:13
Going by the example of the 16-35 and 24-70, the wide angle / normal / medium telephoto lenses will probably be the Tamron 35mm f1.8, 45mm f1.8 and 85mm f1.8 respectively (given the same weather sealing and Pentax rebadging as the zooms).
Posted 03/07/2016 - 17:48
johnriley wrote:
I'd be most interested in a fairly wide prime lens, perhaps about 20mm.[/quot[quote:3496ace15f="johnriley"]I'd be most interested in a fairly wide prime lens, perhaps about 20mm.
I am with you there John, I am looking for a wide FF lens for landscape; considering the new 15-30mm but it won't take filters and anyway a prime would be much lighter.
12 years
Warwickshire
