Simple bodge to use IR remote from behind camera
OldTaffy
Posted 29/05/2022 - 13:09 Link
My K-S2 has its sensor for infrared remote control at the front, like many other recent Pentax DSLRs . Annoyingly one needs to have the IR remote in front of the camera to get it to work. The camera will just about pick up the IR signal up to about 90 degrees on the 'starboard' side. A big lens will block any signal from the 'port' side.
I have been using a simple bit of shiny aluminium kitchen foil to reflect the IR signal when catching some images of the birds on our bird table. Clag a scrap of foil to the inside of the grip with blutack or sticky tape, bend it around enough to stick out a bit at the side at an angle that will reflect an IR signal from astern back onto the sensor. See attached photo.
Now I can sit in comfort with a mug of coffee, camera on tripod pointing out of the window, and click the shutter from my chair when I see something interesting on the bird feeder
Posted 29/05/2022 - 19:01 Link
OldTaffy
Posted 29/05/2022 - 20:05 Link
GrumpyGrandPa wrote:
Why not use the Image Sync app as a remote control?
https://www.ricoh-imaging.co.jp/english/support/download/app/image-sync/
Because I don't have anything that will handle the app. I don't own, nor want, a smartphone
Posted 29/05/2022 - 20:10 Link
Fair enough!
pentaxian450
Posted 01/06/2022 - 01:00 Link
It is also very easy to do a corded remote with a 2.5 mm audio male connector and a simple contact switch. With such a remote, you can put almost as much wire length as you want (within reeason), and it is never hit or miss. Corded remotess are the most reliable system one can use. You could also use a stereo 2.5 mm audio male connecteer with a three position contact swith and also activate the AF.
Flan
Posted 01/06/2022 - 13:46 Link
Thanks pentaxian450. That’s very helpful for me at least. I presume this will work on the KIii also and the k70?
Aitch53
Posted 01/06/2022 - 17:12 Link
Or put a small mirror (shaving mirror? Borrow one of your other half's compacts?) on the window sill, angled to reflect the light to the remote-sensor?
SteveH!
I prefer 'unconventional'.
OldTaffy
Posted 01/06/2022 - 18:33 Link
Thanks, most useful info. Wired remote would be ideal.
You don't say which models of Pentax dslrs allow this. The K-S2 is a rather odd beast. It has a 3.5mm (not 2.5 mm) receptacle for an auxiliary microphone input, but no other audio jack-plug socket. There are miniature HDMI and USB connectors, but these are primarily for downloading images to a computer or when operating in live view (not recommended if the camera is left on for long periods of time).
Surely the external mic input will not double as a wired remote input - or will it? I hesitate to try!
Regards, Martin.
pentaxian450
Posted 02/06/2022 - 00:19 Link
The mic connector doesn't act as a romote connector. All the Pentax DSLR cameras I've had (K-10, K-20, K7, K3 and K3 III) all had a separate jack for the wired remote. However, the Pentax corded remote is expensive and short, so I made my own. I've also made "special" wire connectors to use with my Gigapan Pro V (the wire that comes with it didn't support AF) and one for the Manfrotto MVG 460 gimbal. Unfortunately, it seems like the K-S2 doesn't have a jack for a wired remote (what a shame). However, if anybody wants to learn how to make those wired remotes, just let me know, and I'll try my best to explain how to do them.
Edited by pentaxian450: 02/06/2022 - 00:20
coker
Posted 02/06/2022 - 09:07 Link
Thanks, that would be most interesting, for use with my macro work!
Coker.
neiljgriffs
Posted 02/06/2022 - 12:22 Link
K-70 uses mic port for shutter remote, dont know about any others k-r hasn't got a mic port
