Sigma lens problem
Posted 21/10/2009 - 14:28
I heard that with some you need to wobble the lens a bit so that it makes a better contact, so if it isn't the aperture ring then it is that.
it can also be a Sigma issue since you use a newer camera the chip in the lens might need to be replaced.
Posted 21/10/2009 - 15:19
Might be true but you never know right, simply eliminating all options here. Just in case...
Posted 21/10/2009 - 16:01
Mike-P wrote:
Is the aperture ring set to A ? (presuming it has one)
It is now AND it's working. Simples, as Yuri the meerkat says. That is when you know how...many thanks indeed MikeP.
Beware the whitevan man!
Aviemore
Thanks in advance,
Joe
