Sigma 17-35mm f/2.8-4 EX DG
Posted 19/05/2010 - 22:22
Sounds OK. Ffordes had some and I think fleabay one went for £150. I was looking hard at these before stumping up for the 17-50.
Lurking is shirking.!
Posted 19/05/2010 - 22:25
Thanks Doug It looks a very good deal but I am not experienced enough to really know but non of my lens are this wide and I just fancy this type of lens thanks again.
All the best
Posted 20/05/2010 - 09:28
I'm guessing this lens was intended for a full frame camera? If you're going to use it on a Pentax dSLR I'm not sure if £130 is worth it. You should be able to pick up a Tamron 17-50 for around £200 used, and to me the constant f2.8 and extra length would be well worth the extra £70.
77mm is a huge filter size too, which means added expense if you look into polarisers and other filters. The Tamron is 67mm.
Tim
London
Thanks in anticipation.
