Sigma 100-300mm F4 - focusing beyond infinity
jeallen01
Posted 27/05/2013 - 11:50 Link
This was happening a lot yesterday at Duxford - would it be possible to get the lens repaired so that it does not do it?
Also, apart from Sigma UK, can anyone suggest a repairer in the London area which could do the work?
Thanks in advance.
John
Posted 27/05/2013 - 17:49 Link
Sigma TARIFF No.7 £131.99 min,
or £52.99 per hour till fixed
johnha
Posted 27/05/2013 - 18:28 Link
Are you sure it's a fault? Most zooms today aren't true zooms, rather they are varifocal lenses - in that you have to adjust the focus when you zoom. A true zoom (parfocal) doesn't do this.
It may be that in order to achieve infinity focus at one end of the 'zoom' range, it may take the other end over 'infinity'. It may also have been that what you were shooting wasn't close enough to infinity - with a long lens this can be quite far. Environmental conditions may also have an impact (pressure, temp & humidity).
Look here: link
An annoyance yes, but possibly not a fault (at least not one that can be easily corrected).
Regards,
John.
Edited by johnha: 27/05/2013 - 18:33
Posted 27/05/2013 - 18:30 Link
Many lenses focus beyond infinity so it's not really a problem. It's usually long lenses and this is to compensate for dimensional changes with temperature, which can be significant with a huge body of metal and glass.
John's reasoning may well also be quite correct.
jeallen01
Posted 27/05/2013 - 20:48 Link
Thanks for all the replies - the main reason for wanting to get this fixed is that when the lens does this, it then takes even longer to get to the point where the focus locks on to the target (which, for me, might be moving very fast!)
johnha
Posted 27/05/2013 - 23:33 Link
I appreciate the problem, it's one I have on my Sigma 70-300, but it works better in AF-S than AF-C. It seems to have to hit the end-stop before it switches direction.
I always wondered whether there's a drawback with the Sigma AF lenses focusing the 'wrong' way to infinity (compared to Pentax). Not only does the focus ring of my 70-300 go the wrong way, so does the screw-drive connector. Sometimes I wonder how the camera manages to focus at all!
John.
jeallen01
Posted 28/05/2013 - 08:20 Link
John.
Hi
I think I have to agree with you on all your points, especially the need to hit the end stop and the issue of the "wrong" way
jeallen01
Posted 12/06/2013 - 15:36 Link
The lens got sent back to Sigma Imaging by DHL (that's a long and painful story = "Don't Hurry - and then Lose it"!).
When it finally got there, the Technician (Daniel) checked it out and confirmed to me that the focusing beyond infinity is per spec (something to do with something that Canon introduced for mirror lenses many years ago, and then got spread across the whole lens range ) but that it is front-focusing at 100mm, so he can fix that anyway. Better news = that's just recalibration and costs £37.99 instead £131.99!
We'll see what if any difference that makes when I get the lens back in about 10 days.
John
Mike-P
Posted 12/06/2013 - 16:10 Link
I had a Canon mount Sigma 70-200mm f2.8 that I bought for peanuts as the AF was not working, sent it to Sigma who fixed it (that cost about £130) and I'm not kidding, when it came back it was so sharp it was unbelievable. Would be interested to see what your 100-300mm is like on it's return, mine seems pretty reasonable wide open at 300mm ... so much so I'm thinking of selling the DA* 300mm prime.
Gamka
Posted 12/06/2013 - 16:34 Link
or Drop it, Hide it, Lose it
jeallen01
Posted 12/06/2013 - 16:50 Link
Even Better!
BTW - when I spoke at some length to DHL yesterday, their complaints handler said that they have heard that sort of thing before over the years
jeallen01
Posted 12/06/2013 - 17:45 Link
Chosen quickly at relative random:
Duxford 0n 26th May - F86A Sabre - maybe not quite what you wanted - but about F11 @450mm (100-300+ Sigma 1.4x) @ 1/1250th of a second in AF-S mode
Not cropped and completely un-retouched etc. - and shows me that I should have cleaned the sensor before I went!
Edited by jeallen01: 12/06/2013 - 18:01
jeallen01
Posted 22/06/2013 - 14:53 Link
Update - the lens arrived back from Sigma on Thursday and I may have a chance to try it out over the weekend, but probably next weekend is more likely.
Edited by jeallen01: 22/06/2013 - 14:53
