shutter speed problem K-5
Posted 06/09/2014 - 16:21
P.S .... just tested the TAv mode where I can change both shutter and aperture and it works fine for that.
Posted 06/09/2014 - 21:33
Might be worth trying loading the latest firmware - or re-loading it if you are up to date - or re-setting to factory settings.
Carl
Carl
Posted 16/10/2014 - 02:51
Hello uksweetheart, here is the FIX: See Item 7 in the custom settings menu, turn OFF Auto EV Compensation.
Also play with the edial programming menu in Tv mode for a fix.
Sorry for a late reply, as I am on a long holiday to Canada and did not check out the Forum.
Regards.
nanhi
camp: Thornhill, Ontario
Regards.
nanhi
12 years
