Should I be concerned?
DaveN
Posted 12/07/2011 - 15:34 Link
Discovering the joys of photography with Pentax
Mannesty
Posted 12/07/2011 - 15:39 Link
Probably, but it'll be a warranty job if it's the staing problem.
It does look like the staining issue to me.
What are the first 2 digits of your serial number?
When was the camera made?
Edited by Mannesty: 12/07/2011 - 15:40
DaveN
Gwyn
Posted 12/07/2011 - 15:43 Link
Yes you should be concerned. Classic staining. A warranty job as Peter says.
Good luck!
DaveN
Posted 12/07/2011 - 15:44 Link
(Serial No 400XXX, build date Feb 2011
japers45
Posted 12/07/2011 - 15:52 Link
Looks almost identical to the stain I had. I was gutted but it was sorted very quickly and efficiently by JP.
Mannesty
Posted 12/07/2011 - 15:53 Link
Eeek, mine is close to that at 402xxxx, built in April 2011. I'll have to keep an eye on it.
I had thought that all bodies with serial numbers starting with 4 were not affected by this.
Posted 12/07/2011 - 15:54 Link
Please don't double post in the forum, I'll leave this one an remove the other one. All that happens is you get two competing threads evolving.
DaveN
Posted 12/07/2011 - 15:58 Link
Fair enough John. I thought I'll post on the other thread as my Camera is from batch that's supposed NOT to have the stain issue.
Gutted as I'm just about to go on holiday
Posted 12/07/2011 - 16:02 Link
Not a happy situation for sure. I'd be tempted to take it on holiday and just clone out the offending marks on any images where it shows. It could be fixed under warranty when you return.
Gwyn
Posted 12/07/2011 - 16:16 Link
Mine replacement is older and close in serial # to many with stains, but is showing no signs (yet) so don't panic Peter.
DaveN
Posted 12/07/2011 - 16:46 Link
Should I even bother?
The above two images were taken with my new Sigma 10-20.
I changed over to the DA*300 to do some more tests:
On clear blue sky, I cannot see any stain (f13-f32)
On white clouds, I can barely see then at f16, but visible f22 onwards
I am wondering whether I should just accept this is within normal limits of manufacture or ask for a warranty repair when I come back for holiday
davex
Posted 12/07/2011 - 17:00 Link
Definitely, even if you can live with it ;
a) The resale value is severely diminished.
b) It is a manufacturing fault, why would you not want a replacement?
c) You will always know it is there, it will always be an issue.
Think the way Pentax and its distributors have reacted this is not the case.
Have a good holiday, then get it replaced.
Dave.
My flickr: link
DaveN
Posted 12/07/2011 - 17:10 Link
Ok at ISO 100, f22 it is visible as below:
[IMG]http://img199.imageshack.us/img199/4168/pntx0836crcr.jpg[/IMG]
bforbes
Posted 12/07/2011 - 17:15 Link
just take the advise and get it replaced.
