Shooting tethered with K20d
Posted 25/11/2008 - 12:23
When you say the shutter locks, do you mean you cannot press the shutter release? Or does the shutter lock open with the mirror up?
The first is expected, the later is a serious problem.
You'll need to download Pentax's Remote Assistant. You can configure it to dump photos to a folder. Then lightroom should be able to detect new images there and allow you to work on them. (I don't have light room so I can't say the exact behavior.)
Pentax has not released the APIs, so thee is no third party integration... which would be really nice... but the watched file should be perfectly sufficient and you can still make good use of the tethered shooting.
Posted 25/11/2008 - 14:46
IIRC you have to change a setting in PRA to allow the use of the shutter and wheels on the camera.
There is also a problem with LR1 & LR2 watched folder and pentax files, the first shot is loaded but all subsequent shots stay in the watched folder I was never able to get this fixed so I just used Capture One, Picasa2 or Bridge set to the watched folder.
Brian.
Brian.
Posted 25/11/2008 - 15:28
Hi Guys
Many many thanks for all the info. I think I am getting there. Brian how is the Kingdom and as for Virginia is that something to do with Virgins? Seriously though many thanks, so kind of you to take the time.
Posted 25/11/2008 - 15:35
hamiltonsmith wrote:
Hi Guys
COLD
Hi Guys
Brian.
Brian.
Posted 25/11/2008 - 15:53
... and no virgins here either.
Shepshed
