Shake reduction when using a tripod?
Posted 28/01/2011 - 22:17
All manufacturers say the same and the feeling is that if there is no shake to correct it causes the syetem prioblems in that it's looking for shake.
It may also be that when on a tripod and maximum sharpness is needed, switching off SR locks the sensor into place. This might apply to macro work.
Posted 28/01/2011 - 22:19
If you use a remote or the delay timer SR is switched off automatically. I always use a remote when using a tripod, so SR is always off for me.
Posted 28/01/2011 - 22:24
True Gwyn, good point. I use the 2 second delay which also switches off SR.
Posted 28/01/2011 - 22:30
Thanks for those replies. I do usually use a remote when using my tripod so all should be well.
Regards, Philip
Forest Gate
