Shake reduction not coming on on K-5..
Posted 29/12/2010 - 14:27
Do you have it set to 3 second timer or remote by any chance? Then the SR is automatically switched off.
Posted 29/12/2010 - 17:42
i'm having a similar problem. When i go to the control panel after pressing info the SR is not highlighted so i can't select it.???????
I'm still playing around with it so here's hoping.
Posted 29/12/2010 - 17:50
Bulb mode also inhibits SR (on the K20 at least).
Posted 29/12/2010 - 18:17
Have you switched it on in the menu? Page 3 or so of the first menu- I think it is off as standard and needs switching on there.
Posted 29/12/2010 - 18:51
Amazing! Problem solved, I thought there was nothing wrong with my eyesight but maybe I need a new brain too!Do you have it set to 3 second timer or remote by any chance? Then the SR is automatically switched off.
Thanks so much
Posted 29/12/2010 - 19:03
Glad to have helped .
Posted 29/12/2010 - 23:59
Sorted it out on my Kr. Can't select Shake reduction in timer mode. Also found out that the HDR can't be selected when shooting raw.
It takes many reads of the manual for it to all slot into place.
Whitehaven,
Cumbria
Thanks a lot
