Setting AM or PM in K10D?
Posted 17/02/2008 - 13:55
I have the proper city selected, and the date and time filled in correctly, but it tells me it is PM when it is AM, and AM when it is PM. The cursor will not move to the AM/PM to select and change it. Does anyone know how to make this change?
Are you sure you haven't just set the time 12 hours wrong?I have the proper city selected, and the date and time filled in correctly, but it tells me it is PM when it is AM, and AM when it is PM. The cursor will not move to the AM/PM to select and change it. Does anyone know how to make this change?
You can't change AM/PM, you have to cycle through the hours to get to the correct time - the AM/PM display is automatic based on the time you've set.
It's slightly more obvious if you switch to a 24hr display, and set the right time, then switch back to 12hr display.
Posted 17/02/2008 - 15:30
That did it! Thanks!!!
22 years
