sensor/lens cleaning?
Posted 13/08/2009 - 09:38
I, like many others, use the Arctic Butterfly. If you go to a camera shop they will probably use one of these and charge you £40 (which is the price of the basic kit).
Personally I recommend buying the travel kit. It cost around £100 but will pay for itself in a couple of years.
Posted 13/08/2009 - 10:10
i have tried the sensor cleaning function on camera menu but battery runs out it says should have it plugged into mains but havent got mains adapter and i have tried the swab things but they leave it smeary and dont remove blotches
Emma
"Photography is a way of feeling, of touching, of loving. What you have caught on film is captured forever... it remembers little things, long after you have forgotten everything." Aaron Siskind
Bodies K20D, LTL 3, K1000d
Lenses Pentax 50mm, Pentax 135mm, Tamron 70-300 macro
Posted 13/08/2009 - 10:24
If you have a charged up battery it should clean the sensor as it only shakes it a bit. I have it set to shake each time the camera is switched on - not everyone thinks this is a good idea.
There's a knack to wet cleaning with swabs and I would regard that as last resort but since you have them what make are they? Blowing and arctic butterflies won't help with the smearing.
Better advice will follow no doubt
Posted 13/08/2009 - 10:31
i dont no what make they are when i brought my sigma lens i got them didnt quite no what they were but the shop man said they were v good got liquid with them as well just orange swabs thats all i no : im just a ammy trying to take the next step but not got a clue
Emma
Posted 13/08/2009 - 10:37
Well I think you need to wait for better advice than I can give but Google Eclipse cleaning swabs and I think they tell you how to use them. This wasn't a lens cleaning kit was it?
Posted 13/08/2009 - 10:39
again no idea and i did fully charge by batt before doing the sensor cleaning but still run out
Emma
Posted 13/08/2009 - 14:52
Hi Emma,
I always try to clean first by a blower (I hold the camera body lens mount down and blow up so that dust will fall out, hopefully), then with artic butterfly, and if that doesn't work with swabs and eclipse 2 fluid.
NB your GX10 will require Eclipse 2 not Eclipse due to the tin-oxide in the sensor cover
www.cleaningdigitalcameras has extensive information on how to clean the sensor along with evaluation of different methods.
Cleaning supplies can be purchased from www.micro-tools.de.
Cleaning the sensor is not as fearsom a job as it sounds and is something which all DSLR users have to come to grips with sooner or later.
Good luck
Bob
Bob
Posted 13/08/2009 - 17:04
If you've fully charged the battery then it should hold the shutter open in the "cleaning" position for quite some time. I would estimete that I've engaged the sensor cleaning option for not more than a minute or so at a time as thats all it takes to do each stage of cleaning the sensor.again no idea and i did fully charge by batt before doing the sensor cleaning but still run out
It could be that you battery is on its way out - do you get significantly less shots per charge than when it was new, GX10 battery should be good for several hundered shots?
Good value for money spare batteries can be had from 7 day shop - £6.99 + p&p.
Good luck
Bob
Bob
Posted 13/08/2009 - 18:23
thankyou for all your advice i went along to jessops today and brought a giotto blower and a microfibre cloth plus liquid and a sensor pen cheaper alternative to artic butterfly which i will get eventually i haved ceaned sensor and lenses and all are great the marks that was showing on images are no longer there so thankyou everyone
Emma
Posted 13/08/2009 - 19:19
Glad to hear it. I think the first time is always the worst!
Posted 18/08/2009 - 17:37
I got the pentax ccd sensor cleaning kit from srs microsystems when it was a lot cheaper - at the time it was around £28 but i see that pentax have virtually doubled the price!. i still think its worth the money as it does an excellent job and i can recommend it.
K7D DA 18-55 mk11WR|50-200 wr|DA16-45|Tamron SP90|lots of manual pentax glass
Barking,
Essex
thankyou
