Sensor cleaning on K10D - make sure you disable SR
PygmyTwittle
Posted 22/09/2008 - 07:55 Link
Hi everyone, something to distract you from photokina:
I have just cleaned the sensor on my K10D using the Pentax cleaning kit.
This involves pressing a rubber pad onto the sensor to pickup the muck, then pressing the pad onto a sticky cleaning sheet to remove the said muck from the pad. The instructions say "do not rub, wipe etc., just press lightly, else you might move the sensor and mess up focusing"
Whilst pressing the pad onto the sensor, I noticed a vibration through the handle. So it turns out then that selecting the sensor cleaning option from the menu which is there specifically for sensor cleaning does flip the mirror but doesn't automatically disable the shake reduction. Bit of an omission, I would say. At the very least, would have been nice to have had a warning in the cleaning kit instructions, along with the very useful things like "don't try and clean with bulb mode"!
I do feel a bit stupid however, because if I hadn't had some music playing at the time, I probably would have heard the SR in action before making contact with the pad.
Seems to focus okay still, but I'm not sure I'd be able to tell if the sensor had moved just a small amount. What focal length/focus distance would show up a problem the best? I have 10-17 fisheye, 18-55, 50-200, 77 and 100 macro.
Has anyone else made this mistake and had any problems subsequently?
Any assurance/advice appreciated,
Derek.
Posted 22/09/2008 - 09:07 Link
Derek,
The focus won't have been affected, and TBH I don't think it's a problem.
The CCD is mounted on a fairly large metal plate that moves with electromagnets.
When you disable SR the magnets hold the plate steady. When SR is enabled there is a sensor that works out how to move the CCD-plate according to the vibrations sensed.
It's not as if the plate is mechanically "locked" in any way on the K10D (in fact Pentax made a slight change on the K20D to lock the sensor plate when the power was off. If you move the K10D around when it's off you can hear a dull clunk as the CCD plate moves - which unnerved a few people!).
The instructions about "do not rub" etc - are there to encourage you not to scrub it, but just lightly wipe the sensor. (ie don't try and push it into the back of the camera!)
Still, focus adjustment can be check with a fast lens. The 100mm macro is probably the best option... but then you need to compare to an identical test done before the clean
(I wouldn't lose sleep over it )
iceblinker
Posted 22/09/2008 - 17:51 Link
I've noticed vibration when cleaning even when the SR switch is set to OFF.
~Pete
PygmyTwittle
Posted 22/09/2008 - 18:31 Link
Thanks for the assurenace/info Matt.
I'll be adding a white test shot to my checklist, having discovered all shots from my last outing have a blur from dust on the sensor. I'm meticulous about cleaning the lenses, first time I've had an issue with sensor dust but I've learned my lesson now.
iceblinker, sounds a bit worrying - on my K10D, the vibration definitely stopped after turning off SR.
Cheers,
Derek.
Posted 22/09/2008 - 18:52 Link
Just cleaned the K10D. If you wipe harder and move the sensor, then even with SR off the mechanism still pulls it back into place.
Don't forget that the CCD is held in place only by magnets
EDIT: You'll never get rid of 100% dust. You just get better at spotting it and cloning it out
Edited by MattMatic: 22/09/2008 - 18:52
beginner
Posted 22/09/2008 - 22:02 Link
I looked at these things , but I think I'll stick to my "butterfly!"......
Edited by beginner: 22/09/2008 - 22:03
