SENSOR
Yes, you can clean the sensor yourself - there are suitable kits available from dealers. Sometimes, inevitably, some dust gets on to the sensor and it can be quite annoying.
The best cure is to keep the dust at bay as much as possible. So always turn off the camera before changing lenses. Change lenses in clean areas away from wind and dust. Keep the camera pointing down to minimise the chance of dust ingress whilst a lens is being changed.
This will help, but every time you press the shutter there are a mass of moving parts within the camera and the potential is there for dust to be stirred up.
I have been using DSLRs for maybe 3 years or so now, and so far have not had to clean a semsor, but it's just luck, helped by sensible technique as detailed above.
I wouldn't say I've ever really had a problem with dust, but I do get dust on my sensor. I've found the K10D cleans up much easier than the *istD, with just a quick few blasts of the rocket blower rather than the sensor swabs I used to use.
Dan
You might be amazed, or alternatively I might have to hang my head in shame and retreat back to my darkroom.
As soon as I can I'll post something, but it's likely to be a few days.
Pentax K10D, SMC Pentax-DA 16-45mm, 1/350s, f8
I on the other hand are often in the middle of a windy meadow, or grubbing around in the dirt, so I can only expect dust to be evident now and again.
Dan
Dan
I used to test for dust by shooting a white wall in good light without a lens attached. I got into the habit of doing that before any significant shoot.
After several thousand exposures on the K10D, I've not yet noticed a single dust spec. I'm quite impressed with that.
K20D, K10D, K-m, MZ3, Metz 58-AF1, Optio MX4 & Linux.(No Windows)
(Gone: *istD, ME Super, Super-A)
Dan
Oh, posts crossed, but I can't see the pic.
Think there's a dust spot dead centre, but well blurred due to the aperture. Could be wrong, but there's definitely a bit of a shadow there...
Dan
I'll try a more critical test when I can.
And a fainter one to its left, about 1cm over and down a bit. And another one half way up the flagpole, just a few mm to the left.
Sorry John.
Quite a small file though - are JPEG artefacts a possibility?
Having seen the state of a wildlife professional's sensor I am far more relaxed about mine now.
I have cleaned mine once, when cloning began too take up too much time and didn't always work. There's dust on it again now but it can wait a while.
I've had to do it about four or five times in the six months or so I've had the camera. I usually give the inner element of the lens a blast or two as well at the same time.
London
I HAVE A*IST DL 2 WHICH IS 8 MONTHS OLD
WHICH HAS JUST COME BACK FROM PENTAX AS THE SENSOR HAD TO BE CLEANED IS THIS NORMAL FOR A CAMERA THIS NEW
AND CAN I CLEAN IT MYSELF
