Second outing with a 77mm.
Posted 01/08/2011 - 09:15
I like the way you captured the baby's eyes and the way it's looking around.The last one is pretty good to.Trial and error like you say.
Posted 02/08/2011 - 00:09
Its just getting used to the FIV Don. Some of the above are cropped in slightly. My main concern at the moment is the indoor light focus on the K7. It's not always correct. I'm aware of it and try to refocus as required.I like the way you captured the baby's eyes and the way it's looking around.The last one is pretty good to.Trial and error like you say.
Just about to order a KatzEye screen for it.
Posted 03/08/2011 - 10:38
I suspect this is not the ideal lens for you, and the FOV of a 55mm would suit you better. On a DSLR the 77mm really comes into its own with tight portraits.
Also, the real quality of the lens won't be seen in relatively harsh and constrasty outdoor light. Wait until the evening if you want to shoot outdoors.
But I am glad you are enjoying it. You won't find anything better!
Posted 03/08/2011 - 12:47
There will be better subject matter soon George. The above shots were a few out of desperation on Sunday afternoon. The weather has actually been atrocious here but this weekend forecast is looking good.I suspect this is not the ideal lens for you, and the FOV of a 55mm would suit you better. On a DSLR the 77mm really comes into its own with tight portraits.
I'll work with it and learn its ways.
gold coin. K7, 77mm, ISO 640
gently please. K7 - as above.
parental support. K7, as above, 1/20th sec.
attentive
grips, glass and images
an artist
So far? The 77mm Ltd is not a lens for the casual shooter. It seems very capable and can exaggerate any weakness in the focus system on a K7. For those that use a Katz eye screen and manual focus, it's a lens that can give 100%.
I feel that I need more time and better light to squeeze the best from this lens. So far, it's been a pleasure to use.
The FOV seems just too tight in some situations, that said, to be aware of its requirements is to be prepared and thus requires more thought about the shot.
