SDM Woes
Posted 10/09/2013 - 21:44
The new repairs are done using the latest parts that are supposed to stop failure. The new repairs also make focussing faster so it is worth doing.
Concert photography
Concert photography
Posted 10/09/2013 - 21:48
Could we know the current cost of a SDM repair and where/what company would carry out the repair?
Many thanks
Many thanks
Retired at last - now all that time for photography - you would think: wink:
Posted 10/09/2013 - 21:55
There seems to be to be a pattern emerging with the SDM failures and issues. It seems to happen more often when lenses are used less frequently? Maybe the trick with these lenses is to use them a lot and keep the motor free.
I know this is no comfort to you with regard to your experience but maybe this is something that others might bear in mind? Any thoughts anyone?
Posted 10/09/2013 - 22:19
Thanks everyone - since the lens's failure to focus this morning, I have had it on and off the camera innumerable times trying to coax life from it.
Without success until the last occasion, about an hour after I posted here, when, for no obvious reason, it responded. I'm not sure I quite believe yet in its resurrection - it seems noisier and slower than before - but it'll have the benefit of my doubts tonight and I'll try it out properly tomorrow.
I will certainly take David's advice to use it a lot from now on. I would just add that if a problem does arise, posting on the forum about it seems to stir the Pentax gods in a benevolent way
Posted 10/09/2013 - 22:41
This is why I would never buy an SDM lens unless new, with a two year guarantee.
I've read a lot of comments to the effect that the motors have to be moved once in a while. Even if you don't use the lens for photography, every week or two you should mount it, move the focus ring and engage the AF a few times. It can also help to manually move the focusing ring every time before use, to make sure it's not stuck.
That's all from the many (many) comments I've read during my four-or-so years as a Pentax user.
Best of luck with the repair. I'm sure a few people will have already done it and will be able to say how much it costs and where it can be done.
Posted 10/09/2013 - 23:01
If you buy new niw they should have the new upgraded sdm parts fitted so failure 'should' be minimalised.
Concert photography
Concert photography
Posted 10/09/2013 - 23:03
Ive owned my 50-135mm for over four years now and it it regularly gets used and never has any focus issues. My 16-50 which i bought used shoots around 600 images a week and havent had any focus issues with that one either.
Concert photography
Concert photography
Posted 10/09/2013 - 23:53
Many thanks
Around £120 to fix it - Johnsons seem to be the firm to go to. I speak from personal experience.Could we know the current cost of a SDM repair and where/what company would carry out the repair?
Many thanks
The DA* 50-135mm lens is my most used lens. It was rarely off my K5 until recently. The auto focus packed up about 18 months ago and I sent it back to SRS who sent it on to Johnsons for repair.There seems to be to be a pattern emerging with the SDM failures and issues. It seems to happen more often when lenses are used less frequently? Maybe the trick with these lenses is to use them a lot and keep the motor free.
Now its packed up again and its out of guarantee. Looks like another £120 repair job. Its a lens that costs around £900 new and its super sharp when it works and I use it so much so I guess I'm going to have to bite the bullet.
Posted 11/09/2013 - 18:10
Mike-P wrote:
Many thanks
JP Service Solutions, approx £180 less 20% if you are a PU member (worth the £10 joining fee just to get the 20%)Could we know the current cost of a SDM repair and where/what company would carry out the repair?
Many thanks
Thanks for the info regarding repairs - fingers crossed I don't need to need the services of either repair centre for the 300 or 60-250
Many thanks
Many thanks
So, I gambled and lost, and lens failure is not quite the end of the world .... But it is quite expensive to put right and I just wonder whether anyone on the forum has tried the firmware fix on the lens that allows it to use the camera's screw drive and, if so, whether they've any particular advice to offer. I am a little reluctant to invest more money in SDM, since I imagine any repair would only carry a 6-month guarantee.
Did I mention, it's a brilliant lens. But not one I fancy focusing manually.
ChristopherWheelerPhotography
