SDHC card size for K10
Posted 03/04/2011 - 14:42
I'm have using 8GB with no problems, not ventured to 16's yet.
Chris
Posted 03/04/2011 - 15:02
PentaxExpert wrote:
Do you know in theory if it will handle the 16gig?
No idea !
Chris
Posted 03/04/2011 - 15:22
I just put a 16 Gig Transcend card into my GX10, and it said it had room for 965 DNG files. I assume the K10D would also be happy.
Posted 03/04/2011 - 15:29
SDHC limit is 32GB, I believe !? then it's SDXC !!
so I would think the K10 should manage that
K-7 | K10 | DA 18-135 | DA 18-250 | DA 55-300 | DFA 100 |
Posted 03/04/2011 - 15:36
SDHC spec is up to 32GB so all equipments capable of taking SDHC can read/write up to 32GB.
Posted 04/04/2011 - 05:57
Used 16Gb cards in my K10D no problem.
Posted 04/04/2011 - 14:53
I've bought (and still use) 16Gb cards in my K10, as well as assorted smaller cards, but am not planning to replace them when they do go belly-up as any size of card can do, at anytime. I've had a couple of cards fail on me now - both of which would be classed as reputable brands - and been unable to recover any data from them.
I've just checked and the 4Gb card in my new K-5 at the moment will store 79 shots (RAW+JPG), which is still too many too risk losing, but I seldom need more than 2-3 cards of that size for a day out. I find it's no big deal to change a card compared with the potential inconvenience of losing massive amounts of data.
Obviously if you're taking hundreds and hundreds of shots in burst mode you may have a different perspective...
K-5, K10D, Optio S4
Pentax 18-250mm, 50mm f1.4, 1.7x telecon/AF adapter; Sigma 10-20mm f3.5, 24mm f1.8 macro, 50-500mm, 600mm; Tamron 90mm f2.8 macro.
Grips, 'pods, AF adapter and more bags than a Tesco checkout...
Bradford
It's not about what kit I've got, its about having the knowledge to use it to maximum potential.
