Sd card troubles...Help needed
stub
Posted 07/10/2013 - 12:37 Link
I have just recovered some images from my 16gb Sandisk SD card. Using rescue pro software. All was successful, except now my K5ii or K-7 wont recognise the SD card in the chamber, No red light comes on when I insert it. Just get message "No card in camera". I have tried reformatting the card in my computer. To fat32 and all works well there, but not in camera. Anyone got any ideas of anything I could try to restore the card. Other cards are working fine in camera..
Stuart..
Edited by stub: 07/10/2013 - 12:38
Posted 07/10/2013 - 13:04 Link
Try formatting the card in a different camera, Pentax or any other. Then try again, formatting in your own camera.
We had a card once that wouldn't work in my K20D but formatted in Sue's. After that, it worked again in both cameras.
If all else fails, ditch it and buy a new one. The last thing you want is a day's photography only to find the card is corrupted and the images are lost.
JohnX
Posted 07/10/2013 - 15:17 Link
The fact that you needed to use recovery software indicates an issue with the card.
Had it long? Trouble with Sandisk is that they are THE card counterfeiters brand of choice.
Edited by JohnX: 07/10/2013 - 15:19
stub
Posted 07/10/2013 - 16:29 Link
Why, there was no problem with the card, and it had given good service. Until "I" accidentally deleted a file from it. This was subsequently recovered. But has left the card not recognised by the camera.
Stuart..
Posted 07/10/2013 - 16:37 Link
Did you delete the file from the computer? If so, that could be the reason for the problem.
Have you tried formatting in your other camera yet?
stub
Posted 07/10/2013 - 17:00 Link
No I still have the recovered file. I only have two Pentax cameras John. I get the message "No card in camera" in both the K-7 and the k5ii. I was presuming I could just reformat the card but apparently not...
Stuart..
Edited by stub: 07/10/2013 - 17:01
Posted 07/10/2013 - 17:08 Link
To be honest if it looked like the card was corrupted, as it does, I'd ditch it and buy a replacement.
cabstar
Posted 07/10/2013 - 17:29 Link
I recently sent a sandisk 45mb/s card back to sandisk as the lock tab had fallen off, it cost me around £8 but they replaced my faulty card with a 90mb/s card so well worth sending back
Concert photography
stub
Posted 07/10/2013 - 17:43 Link
That's my next step. Just thought it would be a fairly easy solution. If I get the same result I'l be happy,....
Stuart..
SteveEveritt
Posted 07/10/2013 - 18:08 Link
Pop it in you camera and locate Format card in the menu, sorry if I'm being obvious but I don't see it mentioned yet.
stub
Posted 07/10/2013 - 23:42 Link
Bit to obvious Steve, That option is greyed out in the menu. When the camera does not sense the card. Im going to send it back to Sandisk see what they make of it.
Stuart..
Gamka
Posted 08/10/2013 - 11:32 Link
£8 - extortionate.
£1.30 or so, with Royal Mail. It is insured up to £60 so just proof of posting is all that is needed.
The two I have returned have gone that way and arrived in CZ a couple of days later.
Gamka
Posted 08/10/2013 - 11:35 Link
Before you send it back you need to have an On-line SanDisk account which is easy to set up, then register the card with the date and place of purchase. You can go back a couple of years if you need to.
They say used tracked but as commented in my other post RM First Class is normally adequate.
cabstar
Posted 08/10/2013 - 11:46 Link
Gamka wrote:
£8 - extortionate.
They told me to send it via recorded delivery which i did. Air mail is now only insured up to £20 as is first class mail unless you use a signed for service. My original card purchase was for £22 so if it got lost under standard air mail royal mail wouldnt have paid out as its classed as being under insured. Royal mail have got really strict about this due to the recent privatisation...
Concert photography
stub
Posted 11/10/2013 - 13:23 Link
Just to finish the story off with a happy ending. I have today received two new SD cards. Popped in the camera and formatted. Perfect. I wasn't aware until now that most of the decent brand SD cards carry a 10 year warranty. So its well worth registering your cards on the manufacturers web sites. It may only be a small cost. But it is a cost nevertheless to replace them.
Stuart..
