SD card & K-7?
Posted 05/08/2009 - 11:06
Sounds like a faulty card to me. Have you got another you can try?
Posted 05/08/2009 - 11:21
Thanks Greynolds999 - No I don't have another, but buying a spare tomorrow at the same shop. I'll take this one in and explain what's happening
Posted 05/08/2009 - 11:23
The card has a fault take it back best thing is try the replacement in the shop.
Tel,
Posted 05/08/2009 - 11:46
yeah - sadly it only does this intermittedly though so I can't replicate it . I know it's something to do with fiddling between the modes and changing the saving format... maybe it's just me being a muppet
Posted 05/08/2009 - 13:11
What speed is the card? It may be a write speed issue, the camera may be trying to send data to the card faster than the card can record it. I would want to be using a Class 6 card with the K7 to be on the safe side. ( or at least Class4)
.........all the gear, no idea!
Me super, MX, LX, K5,DA 18-55WR, DA 17-70, DA 55-300, DA40 Ltd, FA50 1.4, Samsung D-Xenon 12-24,Samsung 100mm macro M50 1.7(x3), M28 3.5, M35 2.8, M100macro f4, M135 3.5(+others)
Posted 05/08/2009 - 13:40
Hmmm... no clue - and it's at home: I'll look it up when I get back from work. It was the card that "London Camera Exchange" recommended when I got it (top guys btw) - some 16 Gig thing costing £75 or so... As I said I'm totally clueless about digital so didn't even know there were classes of SD cards
Posted 05/08/2009 - 13:54
I would look at My Memory or 7 Day Shop for SD cards. They will be a lot cheaper than a camera shop.
Posted 05/08/2009 - 14:19
Damm - a LOT cheaper!I would look at My Memory or 7 Day Shop for SD cards. They will be a lot cheaper than a camera shop.
I have a lot to learn.
Posted 05/08/2009 - 14:34
Posted 05/08/2009 - 14:39
Just to second Matt's recommendation, I use them pretty much exclusively for camera memory.
Posted 05/08/2009 - 15:36
I have found that if I make any changes to the images via photoshop or any other software that are still on the card then I insert the card into the camera I get the message "Cannot display image"...hope this helps.
Rob
Rob
Posted 05/08/2009 - 19:20
There's no point in using the green thingy if you make everything green.
Surrey
New to this forum and to dSLRs. Have had a K-7 for 1 week now, and I've had to reformat the 16 Gig SD card 3 times already because it ends up at "cannot display image". Is this usual, or should I take the card back to the shop and have a whine at them to get another? =)
Many thanks
