Scanning
Posted 13/08/2009 - 12:00
It's surely just a very cheap digital camera. Use your own!
Posted 13/08/2009 - 12:13
Already have a flatbed scanner and results are great but TOO slow - that is why I wanted comments on the cheap one with a rate of 1 second per slide/negative.
Posted 13/08/2009 - 15:13
Have you considered a slide copier which will fit onto your camera?
SRS have them for about the same cost link and they will fit directly onto the 18-55 'kit' lens.
With your K20D you could end up with 14Mpixel JPGs from each slide / negative although you will have to do the negative to positive conversion in software.
Bob
Bob
Good luck
Bob
Bob
Posted 13/08/2009 - 15:26
It's not for me though - the person it is for does not have a DSLR just a P&S.
Posted 13/08/2009 - 15:49
SRS has these under the Summit brand for £49.
As SRS sell these, they might be able to recommend their capabilities.
At £49 they are probably worth a try.
An alternative quick method is to project the slides onto a screen and take a picture with a camera on a tripod. Obviously the quality isn't very good but they are acceptable.
Friendly Regards
Graham
Graham
Posted 13/08/2009 - 16:23
The scanner doesn't produce results in 1 second.
I have something similar that takes as long to do 4 negs as my scanner does to do 4 pictures.
If you have a slide/neg hood use the scanner!
Cheers, HG
PPG entries.
PPG entries.
Posted 13/08/2009 - 16:38
They claim 1 second ! This is why I am after comments ...The scanner doesn't produce results in 1 second.
Just spoken to SRS and I can have a try there, but they say that the results are acceptable at up to A4 size. Which is plenty - but did suggest looking at the Plustek options which have more realistic 30/60 second scan times.
A flatbed scanner is a no.
Posted 13/08/2009 - 18:46
I agree with SRS that the Plustek is a better option.
When I've used my cheap neg scanner I spend more time adjusting colours and cleaning the image up than it's really worth.
Cheers, HG
PPG entries.
PPG entries.
20 years
LHR/ABZ INV/OSL/ZRH/LAX SNA/SEA/YUL +++
http://shop.telegraph.co.uk/mm-d3136/cat-fhd/hobbies/leisure/photography/convert...
It claims 5MP and 48 bit depth with a JPG created within 1 second!
Father-in-law wants to copy some old slides and negatives (several sets for all the children and grandchildren).
I'm wondering how good it would be when compared to a Canoscan which takes a minute or two for each.
There is no intention to do much with them, but to create a record of his family but maybe a BMP or TIFF would be better.
Are there any nice compact and reasonably priced alternatives?
