Scanners
Posted 26/04/2009 - 14:01
Hi, With your budget you can buy a Epson V500 or a Epson 4990 flatbed.
If you prefer a dedicated film scanner the plustek 7300 would also fit in the budget.A used minolta film scanner is also recommended by some users.
I have no experience of the canon or HP made flatbed scanners .
I ordered a epson 4990 at £122 from amazon last week because I have two type of slides- 35mm mounted and 7cm x 7cm size old Glass Lantern slides so the flatbed would scan these both slides.
regards
regards
Posted 26/04/2009 - 15:15
Difficult one,
for negs and slides, a dedicated film scanner is the only option, I have trouble with dust on the flatbed scanner..
I have a Nikon Coolscan which is well out of your price range. But it's GOOD
I have a fairly old HP flatbed with transparency adapter and I use that for prints and I am happy with it.
Good luck
Good luck
Z-1p, K-1, P50
Posted 26/04/2009 - 15:38
Hi, I've used a Visioneer One Touch 8700 flatbed scanner for several years and, although they're less well known or popular than Canon or Epson, they do as good a job, to my humble eye. Sadly, that model isn't made any more, but I wouldn't write off the brand if you can find a new model with the price and spec you're looking for. I've got no experience of a flatbed that also handles negs and slides but you'd certainly get better quality from a dedicated film scanner. The Plustek seems to be remarkably good value for money, although its ability to handle dark slides lags a little. It should be fine for negs.
Good luck with your search
Al
Al
Posted 26/04/2009 - 16:37
Pwynnej wrote:
Difficult one,
Good luck
The Epson Perfection 4490 Photo has the Digital ICE hardware built in for correcting scratches and dust just like dedicated slide scanners. I do agree that for the best results a dedicated slide scanner is the way to go but given the pricerange a good quality flatbed like the Epson is better than an average slide scanner. I have used average slide scanners and they end up unused after a few tries.Difficult one,
Good luck
EDIT: The Epson Perfection V500 can allso be found within the suggested budget.
Tamron Lenses: 28-200
Takumar Lenses: SMC 55 1.8
South London
Many thanks mm
