Sample K5IIs images
Posted 16/02/2013 - 10:59
1831, 1832, 1833. purple fringing?
CHEERS Vic.
CHEERS Vic.
Posted 16/02/2013 - 11:26
Yes, the DA*16-50 does produce CA & PF, especially at corners (and did this on the mk1 too) - and with strong side lighting as in these shots.
No big deal - I just forgot to apply correction in LR.
That series of three images was there to demonstrate diffraction effects which appear less severe than the K5II. Normally I wouldn't shoot smaller than f/11. You can compare f/4, f/8, and f/20!
Now udpated
Now udpated
24 years
Sussex,
UK
The shots are nothing special. Just some test shots around the office.
I've used almost identical settings for the JPG outputs as I did on the K5 mark 1. A touch of sharpening, and zero or almost zero noise reduction.
The first shot on there IMGP1660 was taken with the DA*50-135, through a window, and it was that shot that made me "Wow" over the mark 2. I had taken a shot at ISO800 with the same lens and similar setup (but not through a window!) that I was very pleased with the resolution and detail - and I still had the image on the SD card to view on the IIs to compare. The texture and fine detail of IMGP1660 was amazing - especially considering it's ISO3200!
I've also added a couple of graveyard test shots taken at f/1.4 on the FA50/1.4. Hugely pleased with accuracy of focus!
http://www.photon.me.uk/pu/k5iis/
Anyway, as I've said - I'm a happy user.
Feel free to download away and have a compare and play!
(I may add some more too...)
