Same Problem as Tel? (poor focus) C&C please
Posted 29/03/2009 - 18:31
Looking at that shot it seems the blue feeder has a lot more sharpness to it than the bird itself.
I know a lot of people manual focus with the Bigma as it tends to give better results.
Also may be worth stopping down a bit more and getting some of it back in processing.
Keep going though as it is supposedly an excellent lens if you can manage it.
Posted 29/03/2009 - 18:44
Thank you, I am just relived that it seems to be me and not the lens, not one you can afford to buy and then ignore. Hope to take it to wildfowl areas and I should have no light problem there.
Thing to do is grit teeth and keep trying.
Jackie H
K7, K20D, istDS, Optio SV, ME
Most used glass
50mm f1.4, 60-250mm, 28-80mm,
Most used glass
Posted 29/03/2009 - 19:45
LOL, my sister lives in Spain and there is no way I could, if I visit it has to be in the autumn or winter and even then I have problems moving around.
Jackie H
Most used glass
Most used glass
Posted 30/03/2009 - 13:38
aminstar
Cracking good post..if I may say so..I think I'll try some similar shots with mine.
Stupid observation from total amateur, please...use of tc when used with slow lens may reduce the effective aperture enough that the camera's autofocus system will no longer work....correct?
Rob
Rob
K20D
MZ 50
Pentax lenses....DA* 55mm f1.4 SDM ....F 35-80 f4-5.6....DA 18-250 f3.5-6.3....F 100-300 f4.5-5.6, D FA Macro 100 WR f2.8.
Centon mirror lens 500mm.
Pentax Flash ....AF 360FGZ
JVC 3ccd GZ MC 500EK camcorder
MZ 50
Posted 30/03/2009 - 14:10
Robin128 wrote:
aminstar
Rob
Pentax quote a maximum of f/2.8 for the 1.7x AF Adapter, but in practice it works OK with f/4.5 and f/5.6 lenses with hardly any darkening on a K10D.aminstar
Rob
shim
Posted 30/03/2009 - 15:04
shim,
Thanks for reply and advice.
Do Pentax still make it, or should I get the Sigma?
Rob
Rob
K20D
MZ 50
MZ 50
Posted 30/03/2009 - 20:04
Robin128 wrote:
shim,
Rob
Sadly no longer made. I'm sure they would sell well if they brought it back. I've no experience with the Sigma but it's been mentioned on here quite a bit.shim,
Rob
shim
Posted 30/03/2009 - 20:47
Can anyone recommend which tc I should buy for my kit, please.
Rob
Rob
K20D
MZ 50
MZ 50
Posted 30/03/2009 - 20:57
Rob
Can I suggest you start a new topic about TC's you might get more infoCan anyone recommend which tc I should buy for my kit, please.
Rob
As this is a K20D focus topic members won't look here
Tel,
Posted 04/04/2009 - 20:39
Well it wasn't the Bigma it was the operator as I suspected here are a couple I took today and although not pin sharp the are acceptably in focus, Phew what a relief all I have to do now is learn to get the best from the lens.
Thank you everyone who offered help and advice it is appreciated and I hope now I am confident in the lens I can start to get some better shots.
[IMG]http://img.photobucket.com/albums/v173/Thordell/Wildlife/OneSparowinthehedge.jpg[/IMG]
[IMG]http://img.photobucket.com/albums/v173/Thordell/Wildlife/OneSparowinthehedgewithseed.jpg[/IMG]
Jackie H
Most used glass
Most used glass
Posted 04/04/2009 - 20:46
Excellent stuff Jackie they look better, pleased your camera/lens are ok well done.
Tel,
Posted 04/04/2009 - 20:48
That first one is a great shot of a very common bird! I like the twigs and foliage. I suspect some will find them distracting.
Second one is a little sharp and I'm not so keen on the look of the creature.
You guys with your feeders in the way should take a look at this! Personally, I want to see birds flying or sitting somewhere natural, maybe I'm alone
Near Spalding,
Lincs.
Thanks for the size tip Tel, easy to do if you save it from Lightroom they make is idiot proof just for people like me
Most used glass
