Running Flash Trigger and Flash at the same time
nu12ul
Posted 26/10/2012 - 00:39 Link
I am trying to work out a way of running a metz 58 on a lighstand (off cmaera), triggered using a aputure trigmaster 2 remote but at the same time run another metz 58 on camera as well.That way i can switch between lightsources by switching of the trigger at my leisure. I don't think i can do this with the Aputure and wondered if anybody would be kind enough to provide some tips on how this can be achieved.
That you in advance.
DaveHolmes
Posted 26/10/2012 - 01:01 Link
I believe the cactus v5 triggers can do what you're asking... You'd need 3 tranceivers to make it work (so may as well order 2 duo packs if that's the route you plan) there's a very good review by member 'ClassA' (?) On the other forum...
You would have to order from jingling from gadget infinity... But don't let that put you off... They're very good.
Digital:
Flash:
Film:
DaveHolmes
Posted 26/10/2012 - 01:04 Link
Sorry re-read your post... One duo pack would work... But if you want 2 flashes off camera and ability to switch between you'd need 3 transceivers (and that would give more options)
Dave
Digital:
Flash:
Film:
DaveHolmes
Posted 26/10/2012 - 14:13 Link
http://www.pentaxforums.com/accessoryreviews/cactus-cactus-v5-duo.html
the 'Class A' review is the 5th down and most comprehensive of the bunch...
Digital:
Flash:
Film:
Frogherder
Posted 26/10/2012 - 14:26 Link
How aout a simple photoelectric sensor slave flash trigger.
If this is put under the second flash it will trigger when the first goes off.
regards
Bernard
DaveHolmes
Posted 26/10/2012 - 15:02 Link
Will that work in a 'one-on-one-off-camera' set up with the same amount of control?
I recomended the V5 as you can use the transciever on the camera's hotshoe to trigger the 'on-cam' flash and the off camera transceiver OR just the off-cam OR just the on-cam with the flick of a dial... It's quite a clever system despite the low price and lack of (P)ttl functionality...
Digital:
Flash:
Film:
Frogherder
Posted 26/10/2012 - 16:18 Link
Sorry I mis read the original text. I thought both guns were off-camera and only one controlled by a single radio trigger.
I'll keep out of it as I know no more
regards
Bernard
DaveHolmes
Posted 26/10/2012 - 23:33 Link
Ha!
I mis-read it the first time too
I use V4's presently and although very good the V5's appear to be a pretty serious upgrade... If you have a few of them (along with flashes) the options are near limitless... Quite exciting (I'm such a geek!!)
Digital:
Flash:
Film:
