Rikenon 1.7/50
terje-l
Posted 10/03/2009 - 12:36 Link
This lens was acquired with my over 30 years old Ricoh XR-2 camera (my very first SLR). The XR-2 has the Pentax K mount.
[IMG]http://i233.photobucket.com/albums/ee91/terje-l/rikenon17-50.jpg[/IMG]
Is there anybody who has some opinion about this lens? Should I keep this as my 50 mm prime, or would I be better off with a Pentax 1.4 or 1.7?
Sharpness seems OK, and using the green button in Manual mode seems to give perfect exposure every time.
Terry
Edited by terje-l: 10/03/2009 - 12:37
RR
Posted 10/03/2009 - 12:48 Link
If you're happy with it Terry, then why change ?
Malo1961
I am not sure,Terry
Wasn't there a issue with those old Ricoh lenses,
about getting stuck to the mount of Pentax dslr's and not getting of any more?
More about it, you can read here. Just scroll down to the bottom of the page.
HIH,
Martin.
Best regards,
Martin.
terje-l
Posted 10/03/2009 - 13:05 Link
Well, I just wondered how much the IQ would improve with a Pentax lens.
Luckily, this does not apply to my lens, it's too old . No protruding pins or contacts, totally manual.
Terry
shim
Posted 10/03/2009 - 13:29 Link
Not quite as good as Pentax and usually poor with flare. The big problem is that they don't have any half stops. Colour can be off on some.
shim
terje-l
Posted 10/03/2009 - 13:34 Link
Will try to make some test shots. The missing half stops doesn't bother me, the camera has half-stop shutter speeds, which compensates .
Terry
isdky
Posted 10/03/2009 - 15:00 Link
I have this exact same lens in my bag, its a good performer, good colour reproduction and decent results in low light. I too have never had any issues getting it off the camera (standard K mount lens). I only have one shot on flickr with this lens:
But have some portrait shots that I have done where it performed well.
It doesn't have the best coating on the front element and as such is susceptible to flare - I put a hoya hmc filter and a lens hood on which seems to reduce flare.
Best of all I picked it up off fleabay for a mere £6.78 including postage about a year ago!
"Real stupidity beats artificial intelligence every time." Terry Pratchett
Flickr Photostream
pgweber
Posted 10/03/2009 - 15:48 Link
I have the f2 (from KR10 Super c1985) and love the sharpness. Prefer it to 18-55 or 50-200 at 50mm.
Feels like a "proper camera" with the 50mm/f2 fitted (probably because I never had a "standard zoom" till K10D).
Happy birthday my K10D, 2 today!
PGWeber
Pentax K5
Tamron 80-210mm & 28mm
andrewk
Posted 10/03/2009 - 23:53 Link
I've got exactly that lens too, also from a KR10 Super from the same era. It is sharper than the 18-55mm MK2 kit lens at 50mm f8 and much sharper at f5.6.
terje-l
Posted 13/03/2009 - 17:59 Link
Did a couple of tests today. I found that both the Rikenon 1.7 50mm and the Pentax 3.5-5.6 18-55 mm Mk II kit lens exceeded the performance of the laser printer used to print the test sheet (ISO 12233 form Cornell University). The interference shown at the 16 - 18 range is also present in the printout.
Rikenon 50mm at f/5.6:
[IMG]http://i233.photobucket.com/albums/ee91/terje-l/ricoh56-1_full.jpg[/IMG]
at 100% crop:
[IMG]http://i233.photobucket.com/albums/ee91/terje-l/ricoh56-1_crop.jpg[/IMG]
Pentax kit lens at 50 mm, f/8:
[IMG]http://i233.photobucket.com/albums/ee91/terje-l/pentax8_full.jpg[/IMG]
at 100% crop:
[IMG]http://i233.photobucket.com/albums/ee91/terje-l/pentax8_crop.jpg[/IMG]
As far as I can see, the Rikenon lens is a little better than the kit lens, so I will add this to my collection. Not bad performance for a 30 odd years lens.
Thank you all for the comments further up in the thread.
Terry
shim
Posted 13/03/2009 - 19:50 Link
They do look identical on those tests, although any 50mm should equal or pass the 18-55mm kit lens. I've run a few frames through my Rikenon 50mm f/1.4 and it's a bit low on contrast, but does have a magenta cast on grey items like roofs and flagging. The resolutions quite good but not in the same class as a Pentax A 50mm f/1.7.... but better than the kit lens. I've also got the f/1.7 50mm Rikenon and I'll have a look at that over the weekend.
It's rarely mentioned because lenses are usually only tested at one distance, but there can be a big difference when tested on something 150 to 200 meters away. Normally 50mm lenses are OK, it's the zooms that fall down. Some are good at long distance, others are better close up.
shim
shim
Posted 14/03/2009 - 12:53 Link
Hi Terry, the f/1.7 that I have looks identical to yours. I did a few quick 150-200m distance checks with it (photos of some houses all at f/5.6) and did the same shots with a Pentax A 50mm f/1.7 that I know is a good performer. I hate to say it but it (Rikenon) might just be slightly sharper than the Pentax It has a very slight purple tint, but not as bad as the f/1.4. The metering seems OK. I'll have to try this out some more.
Quite a bit of info on the web about these lenses, just search Google.
One link you might find of interest.
I also have the 300mm XR APO Rikenon f/4.5 which is quite sharp and small for a 300mm.
shim
andrewk
Posted 16/03/2009 - 13:42 Link
I've taken several test photos with the Rikenon 50mm f2 and Pentax 18-55mm MK2 kit lens at 50mm. I have yet to see one where the Kit lens come close.
I leaned over the garden fence this morning and took several more at f5.6 1/500sec at ISO200. I checked all the Kit lens photos and they look identical. Some were taken using auto-focus and some were focussed manually - no difference between them. All the shots were taken as RAW and processed identically using RawTherapee.
These are 100% crops ........
First the Kit lens
and the Rikenon
The Rikenon seems way sharper to me. There is less difference at f8 - but still noticeable.
terje-l
Posted 16/03/2009 - 23:41 Link
I agree with you, Andrew.
But I guess it's to be expected. Looking at the f stop ranges of the two lenses, the Rikenon 1.7 50 should be at its best at f/5.6, while the kit lens would be best at f/8 to f/11. At least that's my experience.
Terry
shim
Posted 17/03/2009 - 09:27 Link
Andrew, There is a big difference, but the kit lens shot looks diffused? Are you sure that there's not some grease on the lens or filter?
The highlights on the car and postbox are diffused.
I'm having trouble with focusing on the f/1.7, the long distance shots I mentioned earlier were close to infinity and were good, but 10m away very poor, just not sharp at all. I will have to test again today.
shim
