Rigging
walkeja
Posted 22/11/2013 - 11:05 Link
Let's have your comments please about this photo of rigging tackle taken on board HMS Warrior.
Pentax K1-ii and MZ6
ONE UNITED Member
McGregNi
Posted 22/11/2013 - 17:40 Link
Its an effective detail shot and captured nice and sharply, and the strong diagonals make for an effective composition.
I think the exposure could be more balanced (ie less bright sky and a bit of shadow lift to see some more detail on the circular rigging things).
Also the blue fringing (a kind of chromatic abberation) is very strong along the top edge of that metal rod - caused by the extreme exposure contrast. I'm sure a selection closely around it and de-saturation would deal with it.
swarf
Posted 22/11/2013 - 17:49 Link
Have you tried converting to B&W? You might be able to pull out more structure in the ropes and the pulleys. I'd also be inclined to rotate it and crop it to create something a bit more abstract - it might work it might not, but I'd give it a go.
Phil
My Flikr Page link
walkeja
Posted 11/12/2013 - 11:29 Link
Here is a B&W version:-
Does that improve it or not?
ONE UNITED Member
johnha
Posted 11/12/2013 - 13:24 Link
I prefer the original to the mono version. The only other suggestion I'd have would be to crop the left & bottom slightly so the left-most block was similarly tight in the bottom-left corner as the right-most block is at the top-right corner. This would crop out the end of the loose rope - which I find a tad distracting.
Otherwise it's a good striking shot.
John.
