Marlow Sunset
Posted 08/12/2013 - 21:55
It was a great sunset in Sheffield too, the sky was on fire! These shots certainly convey the spectacular sky but I think they are a bit too black in the black bits for me.
BTW, What is the large black blob in the tree to the left of your shots? Looks like some dirt on the sensor, but it's puzzling me as it is in an identical place on the tree although the two images have different perspective, so if it was dirt it would be in a different place?
Posted 08/12/2013 - 22:25
Thank you for your comments David. I think the blob in the tree is a nest of some sort - it appears to be lots of tangled twigs.
Philip
Philip
Posted 09/12/2013 - 00:29
Might be mistletoe.I think the blob in the tree is a nest of some sort - it appears to be lots of tangled twigs.
Dan
Posted 09/12/2013 - 00:36
Lovely peaceful and atmospheric images I prefer the sky colours in the first. I think the 'blob' is one of those OK candidates for cloning out - yes, it was part of the scene, but its actual effect is just distraction, and of course it doesn't look natural.
Posted 09/12/2013 - 03:13
I say leave the blob. It gives something different to a sunset shot and is a talking point.
Posted 09/12/2013 - 07:24
Thank you, Nigel - the changing colours of the sky were amazing for about half an hour.
Regarding the blob -
So, considering the time of year, Smeggy must be right too!
Philip
Daniel Bridge wrote:
Might be mistletoe.
Dan
Thank you, Dan - I had a look around the Web and found this picture, which seems to confirm your suggestion:Might be mistletoe.
Dan
Philip
Posted 10/12/2013 - 09:32
The "blob", which I agree may well be mistletoe, does to me, detract slightly from the image. It is solid and at first glance made me wonder if there was something on the lens as it is the only one. It is common to get clusters of mistletoe rather than a solitary bunch.
Can you extract that small area at the full original resolution for a detailed look?
Posted 10/12/2013 - 22:25
Posted 11/12/2013 - 00:07
Definitely Mistletoe!
The images both look better without it. Some good PP there too.
Herts,
England
#1 - at 4.06 p.m.
#2 - at 4.17 p.m.
They are Jpegs from the camera, the only PP is the downsampling and some unsharp mask applied in PaintShop Pro X4. They are hand-held shots taken on Marlow Bridge from slightly different viewpoints, with a K-5II in the Auto HDR Mode with Auto Align, and using the 18-135mm WR zoom lens.
Philip
