Restrictions - K mount lenses
Posted 27/01/2011 - 17:21
Welcome. It's an abbreviation for a full explanation. Basically aoperture is now controlled from the camera, so any lens needs an auto setting on the aperture ring, marked "A". If it has that, then full functionality for that lens.
If it does not have an "A" on the aperture ring then enable "using aperture ring" in the camera menus and use stop-down metering to release the shutter and get proper exposure. It's just a bit more time consuming.
Posted 27/01/2011 - 17:44
Hi John
Thanks. What you saying is that it's back to manual. If so,that's OK with me as I work most of the time in manual anyway. I wasn't sure if there are any other restrictions such as lens to sensor size. So will a K mount lens still fill the full size of the sensor. I've been using Pentax cameras for about 30 years but migrated to Canon about 4 years ago. I miss my Pentax stuff and that's why I'm investigating the posibility to upgrade/add to my Pentax arsenal again. The question if I buy a Pentax camera ____ Which one.
Posted 27/01/2011 - 17:49
johnriley wrote:
. . . so any lens needs an auto setting on the aperture ring, marked "A". If it has that, then full functionality for that lens.
Not entirely accurate. With manual focus lenses, the only focus point available to you is the centre one.
Posted 27/01/2011 - 18:34
Salmon wrote:
Hi John
Due to the smaller sensor the field of view of your old lenses will be less than your used to - DSLR view is equivalent to a lens 1.5* the focal length. As the lenses more than fill the sensor.Hi John
Old M42 lenses etc can also be used with an adapter...
All this is true for all Pentax DSLRs (except the medium format 645D), so the model you chose will depend on the features you want & the depth of your pockets, though even the most expensive model is reasonable compared to CaNikon
South Africa
Salmon
