Repacement bayonet fitting!
beginner
Posted 07/02/2011 - 18:39 Link
A friend of mine is looking for a replacement bayonet fitting for a lens!...anyone know a supplier?.....(it's for a nikon lens),I said this last bit very quietley!
Posted 07/02/2011 - 20:24 Link
The lens manufacturer/a scrap lens from a camera fair/a repair house.
beginner
Posted 07/02/2011 - 20:29 Link
Cheer's John!
hefty1
Posted 08/02/2011 - 00:17 Link
Some cheap extension tubes should have both male and female bayonets.
Joining the Q
Don
Posted 08/02/2011 - 01:26 Link
not sure if the lens is older "M" type or has electronics contacts.... if the latter you may need a lens with the exact same contact pins... meaning he might be better off swapping the glass out of his lens with another identical lens if he can get one with a scratched element or fungi super cheap..... most people damage the glass not the mount..
Edited by Don: 08/02/2011 - 01:27
Dangermouse
Posted 08/02/2011 - 14:10 Link
I'd go with Don's suggestion - see if you can find a stuffed identical lens with a good mount to swap onto it.
beginner
Posted 08/02/2011 - 17:24 Link
Thanks gentlemen!...the contacts are the problem,along with the positioning of the screw fixing holes.He has checked a couple of his lenses to use as spares but the holes are out of line!.I have a contact from SRS to try,so I'll give them a go!....thanks again!...Ken
