Rechargeable batterty for Pentax K100D Super
Posted 08/05/2009 - 10:03
The current drain on the K100D Super is probably much higher than your old Fuji compact. Notwithstanding, and even though they're GP brand, a fully charged set of 2700's should last longer than 10 shots.
Were they fully charged when you put them in?
Posted 08/05/2009 - 10:05
Cheers! Does it matter what charger I use for the Eneloops anyway?
Posted 08/05/2009 - 10:06
Sure, I have charged 'em fully (both sets).
Posted 08/05/2009 - 13:13
With my istDL2, I used to get problems with rechargeable batteries. I then switched to Uniross Hybrio Rechargeable Batteries and have had no further problems.
Uniross Hybrio have low-drain technology and remain charged for months. They also come ready charged from new.
Friendly Regards
Graham
Graham
Posted 08/05/2009 - 13:49
Any decent charger should work as long as it can handleCheers! Does it matter what charger I use for the Eneloops anyway?
Ni-Mh batteries. It's worth buying a decent one if you
use a lot of batteries. This Panasonic one link should be OK.
Panasonic batteries are also good and 7Day stock them as well.
shim
Posted 08/05/2009 - 14:33
I use Uniross Hybrio rechargeable batteries in my Metz 58 flash and they last for dozens of flashes.
The older I get the faster I was.
Dave
K-3 II, K10D, DA16-85, DA*50-135, DA12-24, DA18-55, DA 50, Sigma EX DG 70mm Macro, Sigma 70-300mm, Sigma DG 120-400mm APO HSM.
Metz 58 AF-1.
My Flickr link
Dave
Metz 58 AF-1.
My Flickr link
Posted 08/05/2009 - 18:01
10 shots is very low, would get more than that from ordinary alkalines
Rechargeables need a good deep charge first few times, stick them on overnight then charge them again when they are fully depleted
(Nice lady at Tantronics told me that)
Used Duracell 2650 NIMH for ages and always been ok apart from draining a bit fast when not in use
Took to using Energizer Lithiums lately, £6.85 for six in Superdrug.
Posted 08/05/2009 - 18:12
Tantronics do a battery grip for the K100D/K100D about £68(Asnman) got one on Traceys camera approx' 1500 shots per charge.
Tel,
Posted 08/05/2009 - 19:06
another vote for eneloops.
Pentax k1000, MX, ME Super, K5iiD 18-55, Tamron 70-300, Tamron 500 mirror, pentax 10-17, 50 1:4, a manual 28, some extension tubes and a bagful of memory cards. That's all i need... and a load of film cameras too... that's it, honest.
Posted 09/05/2009 - 08:10
Can you still get these? looked for one about a month ago and didn't have any luck finding it on their website
Posted 09/05/2009 - 09:22
I have a number of cheapo chargers which charge 2 or 4 batteries at a time, and one slightly more expensive (and bigger and heavier) one which charges each battery separately (one to four at once), and will also go through a complete discharge/recharge cycle.
Every now and then I put my NiMH batteries through the whole cycle and it seems to keep them in reasonable condition.
The great advantage of individual charging is that if one battery is dud, you can see which one.
I now use mainly Panasonic Infiniums (same low discharge technology as Eneloops and Hybrios), and they are excellent. However, it is too early to say how long they last. Some of my NiMHs are over five years old and still going strong.
Posted 11/05/2009 - 12:45
Well, I use Hama 2700 AA cells in my K100D Super. Life is several hundred shots - cannot be exact since I always rotate the two sets of cells before they run right down.
But I have one thought: what format are you saving in and to what memory card? Experience with a Bridge Model N***n was that Raw files took ages to save (almost a case of go away and have a coffee) and ate up the battery. Highest resolution JPEGs saved at once and did not drain the battery. The K100 saves Raw faster than the other brand, but I am still learning the best settings.
Geoff
Geoff
Posted 11/05/2009 - 16:16
I can put in a recommendation for rechargeable CR-V3 batteries - you can pick up a pair (you only need two) and charger for £20. In all the time I had my K100d (before I dropped it into a rockpool :roll I only once even got the battery display to show half full.
Edinburgh,
United Kingdom
What batteries should use for my Pentax?
