Rear screen protector for K3
Posted 17/09/2014 - 11:52
What Mike said, there Brill!
Cheers Jules...
Posted 22/09/2014 - 16:19
Thanks chaps. I have just received one today following your info. Just the job!
Posted 22/09/2014 - 17:03
x2!!!!
Thanks for info
Thanks for info
Posted 29/09/2014 - 15:24
Use one on my K50, recommended by someone on this site. Is great
Pentax K50,FA 35 2.0,FA 50 1.4, DA 18-135 WR, Sony RX100 2, Manfrotto bits...
Posted 29/09/2014 - 17:04
You can pick up a screen protector for 'Ipad' 'Tablet' etc. in any 'Pound shop' and cut them to fit anything......perfect
Regards,
Michael
Michael
Posted 29/09/2014 - 21:58
This is a glass protector , much easier to put on.
Posted 04/10/2014 - 12:43
Ordered an ACMAXX set a week ago, arrived yesterday and fitted today - Here are some quick pics with my Canon P&S:
- take care fitting this one because the screen and the protector are slightly wider at the pentaprism end than at the other one but did not spot that until I had fitted it the first time
FWIW the pics also show the slightly modified Meike MK-K7 grip
that I fitted to the camera - this one has pins that are small enough to fit holes in the bottom of the K-3 body, so all I had to do was to trim some of the ridges off from around the top edge and add some 2mm thick s/a rubber strip to make a nice snug the fit to the K-3 body. (I had the grip before I bought the K-3 as I was going to fit it to the K-30, but decided to use it here instead!)
Posted 14/10/2014 - 16:35
I always use FOLIX screeen protectors, cheap and easy to fit.
AKA Welshwizard/PWynneJ
Lancashire
